      12-01-2013, 01:40 AM   #1
jamze132
jamze132's Avatar
Germany
20
Drives: 228i
"Increased Battery Discharge"
"Increased Battery Discharge" message pops up, usually after the 2nd and all subsequent start-ups throughout the day.
Anyone?
      12-01-2013, 12:17 PM   #2
rodell
Drives: 2010 X6 5.0
This is annoying. If you run the battery down past a certain threshold you get this message. It is intended to let you know that something is draining your battery while you are away from the car.
Even though I don't do short trips, I will sometimes see this message. When I get it I have to charge the battery manually overnight and then there's no problem. I usually have to deal with it when I had to valet park and they forget to press the "start" button twice to shut things down.
The dealer can read the key and see if you are running enough engine time to charge the battery. It seems like it's impossible to ever catch up.
      12-01-2013, 07:28 PM   #3
doug_999
doug_999's Avatar
2545
Drives: 2011 1M/2021 992/2023 X3
Not so good news...
here you go...
http://www.xbimmers.com/forums/showthread.php?t=624552
Probably time for a new battery.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      12-02-2013, 08:00 PM   #4
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
527
Drives: 2020 Mineral White 30d MSport
Anyone?
How old is your battery?
I had the same issue since I dont use the car more than 20 miles per day at most, so they recoded the car with a fast charge cycle instead of the regular cycle and problem solved, maybe you can ask your dealer to recode your car and check if it helps
Good luck!
      12-03-2013, 09:47 AM   #5
jamze132
jamze132's Avatar
Germany
20
Drives: 228i
Thanks for the responses.
The battery is just over 3 years old.
I did have an aftermarket mono amp installed by a BMW mechanic and he assured me that this isn't the problem because he ran the remote turn-on wire properly. Maybe I do need a new battery but I can't believe that at 3 years...
      12-06-2013, 07:25 AM   #6
BigBobDeuce
Drives: 2012 BMW X6M
2012 BMW X6M  [0.00]
In my 2012 X6M (build date 4/2011), I got the same message last year and this year, both when the weather turned colder. It was generally coupled with the comfort access not working to open the doors. Last year, the dealer charged the battery and it seemed to work. This year, the dealer replaced the battery and battery cable entirely, blaming the problem on the battery cable. I mentioned the slow/fast charging scheme to the dealer, who said their tech had never heard of it. I've certainly seen the scheme mentioned enough times on this forum to know that it exists! Good luck.
      12-09-2013, 01:44 PM   #7
motex
motex's Avatar
Costa Rica
527
It exists, some dealers are just lazy........
