FORUMS
- 5
| 12-16-2011, 11:27 PM | #1 |
Official \"High Battery Drain\" thread
Ok guys, just got my first \"High Battery Drain\" message this evening on my 2011 X5 M.
Please feel free to post if you have had this message, and how your dealer went about diagnosing and fixing this error. Thanks for your info....
| Vorsteiner front splitter | ADV-7 22" | ESS | Akra Catless DP's | Akra Evo Exhaust | KW V3 Coilovers | Lux V3 H8 | HR TRAK spacers 20mm |
| 2011 X5M | 2010 Escalade ESV | 2012 Audi S4 | 2001 Audi S4 | |
| 12-17-2011, 12:29 AM | #2 | |
BMW tested the battery and determined it would only hold 20% charge. They replaced the battery under warranty and it has been fine since. I'm not convinced this is faulty batteries or something faulty in elctrical system or alternator, I suppose time will tell if this battery dies as well. good luck, |
| 12-17-2011, 02:53 PM | #3 |
Do you know how much battery life
Is left once the warning appears?
| 12-17-2011, 03:05 PM | #4 |
Funny my 2010 x5m is in the dealership for this right now.
They claimed it was a cable on the negative terminal and the excessive draining also damaged a few cells in the battery. They are in the process of replacing the cable and battery. They are also replacing the water pump recall. The battery was pretty dead I felt like my starts struggled a little to ignite. |
| 12-17-2011, 03:30 PM | #5 |
![]() Drives: 2011 X5 35d Join Date: May 2009
Just had my 2011 diesel in because of a bad battery. Hope it's nothing else!
| 12-17-2011, 05:17 PM | #6 | |
| 12-19-2011, 02:53 PM | #7 |
2 weeks ago I had the "Increased Battery Discharge" error on my 2011 X5 5.0. Dealer took it, checked it out and battery is deemed fine. Suggested I lock it even when garaged so that it doesn't stay awake for 15 minutes after turning it off.
Had the error once last week on a cold start after a weekend of sitting in the garage, unlocked. Since this second error, it has been locked every time it was parked, even in the garage. No issues since then. Although, SA said if the error returns, they will need to recode the vehicle. After the initial error, they researched the issue and deemed it to be a coding issue. My gut says at the next service it will be recoded.
2011 X5 50i: ZCW, ZPP, ZPS, ZRC, ZTP
| 12-20-2011, 10:34 PM | #10 |
it was VOB, my service advisor is the Emerald Team, JC
i picked up the car today and the invoice indicated they replaced the IBS cable and then they also replaced the battery since the drainage damaged the cells in the battery jeff |
| 12-21-2011, 08:47 AM | #11 | |
Got the error again this morning. Awaiting a call back from my SA.
| 12-21-2011, 09:38 AM | #12 |
This happens when the battery isn't holding enough charge. I had the battery in my '09 replaced about a month ago due to this. There is a newer style of battery (AGM), so ask for that
| 12-22-2011, 09:30 AM | #13 |
Swapped vehicles last evening, SA has been trading notes with BMW on resolution. Thanks for the battery info, I'll pass it along.
| 12-23-2011, 05:32 AM | #15 |
Drives: bmw e60 530i 2005 petrol Join Date: Dec 2011
help please
hi jeff/anybody else that may be reading - my ibs cable on my neg batt cable is burnt out - can i replace it myself and any idea how much they might cost me - thanks in advance
| 01-03-2012, 09:32 AM | #17 |
Over the weekend I got the "low battery warning" when filling up with gas, accessory on, engine off and this AM I got the "increased battery discharge" message. They must be related. I drive 40 miles per day so lack of use will not be an acceptable reason.
I have an appointment for Jan 14th to perform the water pump recall so hopefully it can wait. I have a battery tender that I will plug in a few nights a week to keep battery in decent shape. Car seemed a little slow to start this AM..... |
| 01-04-2012, 12:23 PM | #18 | |
They are working on a diagnosis of the battery drain. Glad I brought it in as another day or so it would have required a tow...... I will update. |
| 01-04-2012, 03:33 PM | #19 |
Good to hear some of the responses and fixes you guys have had..
I had missed my scheduled dealer service, so I will update right after my next visit! So instead of an AGM style battery is there a newer deep life cycle battery I keep hearing about?
| 01-05-2012, 01:59 PM | #20 | |
Water pump recall also completed. |
| 01-12-2012, 10:18 AM | #21 |
![]() ![]() Drives: 10 X5 M/05 F430/12 CTS-V Coupe Join Date: Jan 2009
Just had our battery replaced after getting these messages. Dealer tried to say it was our fault for not driving the car for 18 days and said it would be $450. That must be some battery!!!!!!!
This was not the case, as the car is driven almost daily with 29K in under 2 years. Wife called BMW CS and she had them force the dealer to replace for free. Odd thing is that they needed to replace the radio also?????? Very odd.........Steve
10 BMW X5 M Silverstone w/Black on Black interior - Loaded
12 CTS-V Coupe Thunder Gray - Loaded 13 Ford GT500 (650HP Priceless!!!!) as soon as can be delivered 05 F430 F1 - Giallo 08 BMW M3 Interlagos Blue Metallic - DCT (Traded) |
| Bookmarks |
