BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - New England
Mporium BMW
      03-17-2013, 02:31 PM   #1
rubyM3
Melbourne Red | Carbon
Drives: 2008 M3 Coupe
Reputable performance shop in MA?
What are some good well-known shops in MA?
Looking to have bmw compettion carbon fiber front splittlers installed and rear trunk spolier cabrbon fiber (oem painted spolier removed)?
Also will considering an exhaust upgrade and fix exhaust leak, according to bmw gallery the header gaskets need to be replaced. They quoted $500 just to replace gaskets...
New tires/balance
thanks in advance!
      03-17-2013, 06:09 PM   #2
MJM
BMW CCA Boston Chapter - Member
MJM's Avatar
Drives: 2011 E90 M3, ZCP
Give Marco a call at Turner Motorsports. http://www.turnermotorsport.com/
      03-17-2013, 07:56 PM   #3
DopeM3
M Power
DopeM3's Avatar
Drives: M3
If I were you, I would save the money and buy some 3M heavy duty tape and do the installation of both the splitters and spoiler yourself. Easy to do, there are DYI for them here as well for guidance. Just need a heat gun to remove the back spoiler that is on there now.
As for the gasket, there's a few shops which I've heard good things about: Turners, Ace Performance, Kaizen, Bren Tuning, Bavarian.
Shop around for best quotes.
      03-25-2013, 12:23 PM   #4
HK8888
HK8888's Avatar
Drives: '08 E92 M3
2008 M3 Coupe  [10.00]
Bavarian is good.
      03-26-2013, 02:00 PM   #5
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Are you referring to the header to midpipe gaskets or the header to head gaskets? If header to midpipe, it is not a big job. $500 seems like twice what it should cost.
      03-27-2013, 09:54 AM   #6
cgg126
Drives: 2013 Frozen Blue Edition M3
anyone got a good shop to do powdercoating?
      03-27-2013, 11:25 AM   #7
pbonsalb
I have heard good things about Morini, but it is out past Worcester.
      03-27-2013, 02:51 PM   #8
inter1032
Italy
31
Drives: 2013 m3
ive seen a few of the yuppieracing guys recommend midnight powdercoating
theres also a place in peabody on rt 1 across from santarpios
      03-28-2013, 12:45 PM   #9
MA///M3
Drives: 2008 BMW M3 DCT COUPE
Yes, the plac ein Peabody can powedercoat. Reasonable prices.
      04-04-2013, 07:32 PM   #10
Roundown
New tires/balance
thanks in advance!
I did the spoiler myself this past weekend - it's easy, if time consuming (removing the old 3M tape is 90% of the process). Tape works very well, it's rock solid, there's no visible seam and it's not permanent. This is coming form a perfectionist. PM if you need a supply list.
m3post
