07-19-2012, 05:34 PM | #1 |
Admiral General
13
Rep 243
Drives: 2013 F10 M5 FB
Covercraft Form-fit car cover
Anyone tried a Covercraft form fit car cover? Thinking about getting one, but wary about scratching clear coat taking it on and off every day.
07-19-2012, 06:10 PM | #2 |
Rep 6,696
Drives: F30 340i
07-20-2012, 04:25 AM | #3 |
Rep 770
I use one every day to protect paint (FL sun and etc)Like 99% of tools there is a correct methodology to using them
Placing the Cover on a Vehicle Do not place a car cover on a dusty or dirty car (dry surface with a waffle weave towel or remove dust with a car duster) Ensure that the cover fits well and keep the cover clean (dust / dirt between the inside of the cover or the vehicle surface will cause scratching) Purchase a good quality cover that is manufactured from a durable fabric suitable for your local climatic conditions and expected usage. To place car cover on vehicle; start by placing the rolled-up cover on the centre of the roof (do not drag cover across vehicle surface as it may cause scratching) unroll from the middle to the rear of vehicle and then middle to front, unroll left side and then right using mirror `pockets' (if fitted) Ensure that cover is `tight' and attach cable and lock (if required) Remove from vehicle opposite to the above and store dry cover in storage bag (if supplied) Ensure that cover is `tight' and attach cable and lock (if required) Remove from vehicle opposite to the above and store dry cover in storage bag (if supplied) In strong wind conditions when removing the car cover use the side mirrors as 'anchors’. Remove the front and back portions and then roll towards the top. Then, remove the mirror pocket from one side mirror, then the other. Use a similar method when covering the car, by first attaching the mirror pockets to the side mirrors. Removing Cover Pull the front edge up to about halfway along the length of the car, and then do the same with the back edge so that it meets the front edge, you've just got outside to outside contact. You can then fold the cover in half and only have inside to inside contact, and continue folding this way until it's manageable and can be stuffed into a carry bag. Of course, you then need to be very careful when placing it back on the car so that you perform the above operation in reverse order.[/ Extract form an article “Vehicle Weather Protection Covers” - http://www.autopia.org/forum/car-cov...n-covers.html# |
07-20-2012, 11:14 AM | #4 |
Admiral General
13
Rep 243
The more expensive car covers claim to have soft edges and won't scratch if you use them properly. Hopefully their claims are true.
TOGWT what brand do you use? |
07-21-2012, 04:09 AM | #5 |
Rep 770
Websites
How to Select the Right Cover - http://calcarcover.com/how_to_select.aspx#ultraweave a) http:// www.carcoverworld.com/ Europe-http//:www.covercraft-europe.com b) http://www.covercraft.com/ |
07-22-2012, 03:09 AM | #6 | |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
Give your car a good detail, wax it properly, and let it deal with the elements in LA, which aren't that bad to begin with. You wouldn't catch me dead with a car cover. |
