Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Vendors Classifieds
      07-12-2011, 03:01 PM   #1
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: bmw
♦ Sonic MS | MORR MultiForged™ Wheel Line (MS8 & MS10)
Sonic Motorsports
1045 West El Camino Real
Mountain View, CA 94040
tel: 650-733-6506
fax: 650-691-9009
email: info@sonicms.net
We at Sonic MS are proud to present MORR's new MultiForged™ MS8 and MS10 wheels. We are your premier source for MORR wheels.
In 2008, the R&D team at MORR looked into creating a multi-piece wheel program, but was not satisfied with what was being offered at the time. So, in true MORR fashion, the engineering and product development team set out to make a 2pc and 3pc line-up worthy of carrying the MORR name. There had to be a better option to combine the flexibility of multi-piece wheels with the craftsmanship, engineering, attention to detail, and performance-minded pedigree that is MORR.
MORR Competition Alloys
MORR Competition Wheels was established in 2005 and has since managed to position itself as an industry leader and innovator in Craftsmanship, Performance, Aesthetics and distinctive innovations. MORR Competition Wheels designs and engineers its own line of ultra-light weight performance wheels for high-end automobiles. Our main product lines, MonoForged™ and SpunForged™ are not only designed to improve your vehicle's performance but to equally enhance your vehicle's appearance.
Since its introduction in the market MORR has developed wheels that are tailor-made for every application and designed one-hundred-percent based on direct customer feedback. Every wheel is handcrafted exclusively to each vehicle allowing us to engineer a wheel based on specific diameters, width, offset, back pad thickness, brake clearance, and most important load rating. This company culture helps us to provide key breakthroughs in design and engineering that result in unique ultra-light performance wheels that have since their inception become industry icons.
MultiForged™ Wheel Line - Technical Information
MORR MultiForged™ is MORR’s answer to a far behind 3pc market that has remained stagnant in many aspects of wheel manufacturing technologies. The MORR MultiForged™ collection is as different as it can get when it comes to 3pc wheels. Assembly of a MultiForged™ wheel takes 3 hours per wheel, the back-pad is engineered with torque-assisted mounting and Anti-Water rain grooves for water retention prevention, to virtually eliminate any and all possible vibration issues that can occur. Furthermore, all MultiForged™ wheels receive a low curing powder corrosion protection coat on both the outside and inside barrels for additional corrosion resistance and cosmetic appearance. Lastly, because of the use of proprietary assembly components and techniques we are able to torque our assembly bolts close to 2.5 times more than the traditional multi-piece wheel providing a structure that is more resistance to loads. Our fasteners are are stronger, lighter, and much more resistant to corrosion when compared to the zinc fasteners most companies use. Titanium Fasteners are also available.
Additionally, MORR uses a proprietary silicone sealant that was co-developed with 3M to seal the inner and outer parts. This sealant is specifically designed for modular wheels making it preferable for heat resistance, temperature changes, corrosion, humidity and more. And every wheel is assembled and torqued by hand for utmost care. Aside from all of these features, the MORR MultiForged™ collection includes standard features that are only offered as “optional” features by most. These standard features include but are not limited to:
- Race-Prep Precision Machining
- BackPad Precision Pocketing
- Side-Spoke Precision Pocketing
- Powdercoated Inner & Outer Barrels
All of this precise additional machining adds significant manufacturing cost, but dramatically reduces the weight of the wheel, all while maintaining all of our strength and structural integrity criteria when subjected to FEA Analysis, DOT SAE-J2530 testing, and VIA/JWL Testing and registration.
MultiForged™ is a 3PC Concave product line, that unlike anyone else, uses FORGED 6061-T6 inners, outters AND centers – no extruded, cast, or rolled aluminum in 5000 series to be found anywhere. They are custom made to order, in any finish, offset, or width desired from 19” – 22”.
Right now, the MultiForged™ collection is available in two introductory styles: the MS8 (7-spoke mesh concave 3PC) and the MS10 (10-spoke radial concave 3PC). Our MultiForged™ collection represents the most elite 3PC product on the market, taking us 3-years to fully develop. Anybody can make a 3PC nowadays, but very few, if any, do it right. MORR does it right – on a complete new level.
MORR MultiForged™ Wheel Line : Feature Benefit Summary
- The Industry's First Fully 6061-T6 3 Piece Forged Wheel (Inner Barrel, Outer Lip and Center Face)
- Utilizes proprietary MORR wheel fasteners for extreme load resistance
- Hand Assembled & Torqued under the most Stringent Standards and Procedures
- 100% Manufactured and Assembled in the United States
MORR MultiForged™ MS8
- As pictured above | Brushed & Cleared Centers w/ Polished Lip and Silver Inner Barrels
- 7 Spoke Mesh 3-Piece Forged with a Deep Concave Profile
MORR MultiForged™ MS10
- As pictured above | Brushed Titanium Centers w/ Brushed Titanium Lips and Gunmetal Inner Barrels
- 10 Spoke Radial 3-Piece Forged with a Deep Concave Profile
Standard Finishes:
- Powdercoated Silver, Gunmetal or Black
- Choose from Gloss, Matte or Textured Finishes
Custom Finishes
- Brushed Aluminum
- Brushed Gunmetal
- Brushed Titanium
- Tinted Brushed Aluminum
- ...and more, please contact us directly for more information.
We also offer full rim and tire packages including OEM TPM sensors. We utilize the Hunter Road Force GSP9700 Balancer and “Touch-less” Auto 34 Mounting Machine to mount and balance your rims and tires safely and effectively, without risking any damage to your new investment.
Recommended Fitment for E70/E71 (incl. M models)
20x10 ET35-40 Front
20x11 ET30-35 Rear
275/40/20
315/35/20
22x9.5 ET35-40 Front
22x11 ET30-35 Rear
265/30/22
315/25/22
Recommended Tires:
*Please click on link for more information on the tire, including pricing.
Bridgestone Dueler H/P Sport
20 inch setup
Bridgestone Dueler H/P Sport RFT
20 inch setup
Continental ExtremeContact DWS
20 inch setup
Yokohama ADVAN S.T.
20 inch setup
Pirelli PZero Nero
22 inch setup
MSRP Pricing
20 inch - $2010.00
22 inch - $2195.00
*Prices listed do not include shipping and/or tax if applicable. All prices listed above are per wheel.
For best pricing and ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM.
Store Hours:
Mon-Fri : 10AM-7PM PST
Sat: 12PM-5PM PST
Payments:
We accept all major Credit Cards, in addition to PayPal and Certified Cashiers Checks / Money Orders.
We also offer professional on-site installation services for customers local to the SF Bay Area. Please contact us directly for more information.
      07-25-2011, 02:03 PM   #2
Cal@Sonic MS
Drives: bmw
MultiForged™ MS8 Brushed Titanium Center & Lip | **********.com
      08-11-2011, 03:19 PM   #3
Cal@Sonic MS
Drives: bmw
      09-07-2011, 02:58 PM   #4
Cal@Sonic MS
Drives: bmw
      09-14-2011, 03:47 PM   #5
Cal@Sonic MS
Drives: bmw
      09-27-2011, 02:20 PM   #6
Cal@Sonic MS
Drives: bmw
      10-12-2011, 01:49 PM   #7
Cal@Sonic MS
Drives: bmw
MultiForged™ MS8 (Texture Gunmetal Center, Gloss Black Lip/Barrel, Brembo Yellow Inner Spoke-Pocket)
      10-18-2011, 02:31 PM   #8
Cal@Sonic MS
Drives: bmw
      10-26-2011, 07:49 PM   #9
Cal@Sonic MS
Drives: bmw
      12-19-2011, 06:38 PM   #10
Cal@Sonic MS
Drives: bmw
      12-23-2011, 03:17 PM   #11
Cal@Sonic MS
Drives: bmw
      01-23-2012, 06:37 PM   #12
Cal@Sonic MS
Drives: bmw
MORR MultiForged™ MS8. Textured Gunmetal Center, Gloss Black Lips & Barrels.
      02-13-2012, 02:33 PM   #13
Cal@Sonic MS
Drives: bmw
      03-16-2012, 04:12 PM   #14
Cal@Sonic MS
Drives: bmw
      04-09-2013, 01:35 PM   #15
Cal@Sonic MS
Drives: bmw
ttt
      05-31-2013, 04:35 PM   #16
Cal@Sonic MS
Drives: bmw
ttt
