06-14-2011, 10:17 PM | #1 |
78
Rep 684
Upgraded KW V3 and Clubsport from M-World
Due to popular demand, KW has redesigned its damper adjusters and now they come in the form of rotating wheels!
No more counting how many 1/4 turns you've made Enjoy!
06-14-2011, 11:23 PM | #2 |
Rep 277
This is true, I was worried when I got my set that it would be difficult to adjust with the older versions. But I was relieved when I opened the box and noticed the rotating dials. Nice upgrade!
06-18-2011, 08:15 AM | #5 |
Rep 246
Where are the knobs located. Do you still have to go under the car for the front or is it on top under the hood? Also in the rear, is it in the trunk where you can modify the carpet for easy access or is it under the car? Im glad i have not pulled the trigger yet on a set suspension decision.
06-18-2011, 09:37 PM | #6 |
78
Rep 684
The compression knobs are located at the bottom of the shock/strut.
The ones under the hood is for rebound. So are the ones under the trunk carpeting. You will only need to drill a small hole on your carpeting to access the rear rebound. But for a primarily street car you probably won't need to adjust them all the time after initial set up, so drilling may be unnecessary.
06-19-2011, 11:20 AM | #8 |
78
Rep 684
We will recommend the appropriate damping, ride height, and alignment set up for your specific usage.
07-17-2011, 12:49 AM | #11 |
chris
278
Rep 12,144
wow those are excellent! too bad i am stuck with the old set up....
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
07-18-2011, 06:08 AM | #12 |
Rep 5,329
how close can v3's run to factory ride height?? i hate lowered car's here in the uk..... compliance is key, im looking for a set that wont lower the car, or very little if it does.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
07-18-2011, 12:06 PM | #13 |
78
Rep 684
About 0.5"-0.6" lower than stock all around.
