New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      02-17-2011, 07:07 AM   #1
Alext
Drives: B M W
BMS drop in filter for 35i?
Anyone used it yet?
      02-21-2011, 05:56 AM   #2
dcs2k
Drives: E92 M3
Been running this in conjunction with my other mods for a couple months. Butt dyno did suggest it liberate hp on the high end. The only drawback I have is that ever since I had this, my car exhibit some hesitation issue wen I go WOT at times. I stomp on the gas, the rev goes up, everything pause for awhile as if it's out of breath, before resuming the rev climb . Will need to revert back stock air box to determine if the problem is with the dci
      02-21-2011, 04:13 PM   #3
shashi27
Drives: 11 Z4 35is
I have a similar issue. Not sure I am a fan of the sucking sound a 3K rpm. Sounds like I have shop vac under my hood.
      02-21-2011, 07:17 PM   #4
Alext
Drives: B M W
I was actually asking about the DROP-IN filter from BMS that is used in conjunction with the stock air box
      02-22-2011, 08:27 PM   #5
dcs2k
Drives: E92 M3
opps sorry for off topic eariler.
I had also used the drop in filter from BMS. In all honesty cant really feel a difference though will like to think otherwise after spending some money on it haha
zpost
