New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      11-01-2009, 04:23 AM   #1
mrboon
mrboon's Avatar
Drives: Speeeed
Question JB3 Tuning on Z4 35i DTC
Has anyone installed the JB3 tuning kit on their Z4 35i yet?
If so, how much HP did you get. Did you need to make any other modifications? Or did it run on stock air intake / exhaust?
What about the DTC automatic dual clutch gear box, can it handle the torque/hp?
      11-01-2009, 08:48 AM   #2
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
I will have a JB3 + Dual cone intake installed this Tuesday on my Z4 3.5. I will let you know how it goes. I have the same setup on my 135i and I love it. I am going to dyno both cars after to see how much they're putting out....
      11-01-2009, 09:51 AM   #3
dcs2k
Drives: E92 M3
running JB3, map 7 on a dyno yields me 55whp more on a otherwise stock car. no issues with dct as far as I can tell. Been running this setup for 2 mths and no issues so far. Hope this helps!
      11-01-2009, 10:49 AM   #4
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
would it be too much to ask for step by step pics or video?
      11-02-2009, 06:18 AM   #5
dcs2k
Drives: E92 M3
wished I know how they installed it, but i left all the work to the garage . maybe a search might turn up some info ?
      11-02-2009, 07:50 AM   #6
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
Check out the 'tube and the vendor's website. Here's taste from the 'tube. They show a 335i but you can make transition. The e89 is easier because the ecu box is directly accessible, whereas the 3235i is buried.
      11-02-2009, 11:59 AM   #7
billwr
Drives: Z4 35i, sport, 7sp, etc...
The JB3 PNP and BMS Dual Intakes were installed last week on my Z4 35i 7sp with 1500 miles on it. I don't plan on doing any racing, but wanted 'next level' performance at a reasonable price and minimal risk of damaging my car.
I've been using Map 3 (91 octane in CA) and in the first 5 days or so, everything seems to be running just fine. I've not done any measurements, but there is without a doubt a pretty dramatic increase in acceleration/power. Let me put it this way, my prior car was an M6 and the Z4 with JB3 is certainly enough to put a smile on my face when I hit the gas.
The car seems to actually run a little smoother and it doesn't seem to have had any material effect upon my gas mileage. In fact, it's gone up slightly (18.8mpg prior to JB3 and 18.9 for the 5 days after JB3) - even though I've probably driven the car a bit harder (I know there are many other factors that can affect mileage)
I got the impression from BMS that so long as fairly conservative maps are run, there should be no problems with the Z4. Time will tell, but so far I'm happy with it.
      11-02-2009, 02:23 PM   #8
Memphis1
Memphis1's Avatar
cool!!! i'll probably do the PNP
      11-02-2009, 03:11 PM   #9
HPFREAK
Drives: C6 ZO6
You should do the PnP for sure. It is far cleaner and faster to install and take off for warranty work on the car. If anyone has questions about the JB3 or JB+ please feel free to call me.
Brad
My Youtube Channel
      11-03-2009, 04:01 AM   #10
mrboon
mrboon's Avatar
Drives: Speeeed
Sweet i think im gonna order the jb3 pnp
Brad@PSI MOTORS can you confirm that the DTC box can handle the JB3 no problem?
      11-03-2009, 05:35 PM   #11
HPFREAK
Drives: C6 ZO6
There are others running it just fine and I talked to Terry at BMS and says it is fine. Give me a call if you want. happy to talk.
My Youtube Channel
      12-12-2009, 07:13 PM   #12
Alext
Drives: B M W
How did the install go? Any vid?
      12-14-2009, 02:42 PM   #13
mcbeee
mcbeee's Avatar
Drives: '09 Z4 s35i & '03 Z4 3.0i
2003 Z4 3.0i  [5.00]
2001 Z3 3.0i  [0.00]
2009 Z4 s35i  [7.00]
JB+
I'm just thinking about putting the JB+ in my car and have no info on the reliabilty etc of this product. I can't drive the car until next spring so it's no rush (the snow is a little deep ). The cost seems so much lower than others like ESS & Dinan so I wnder how good it really is.
Comments and advice please.....
(I traded my M3 for a new 09 Z4 s35i)
      12-14-2009, 05:14 PM   #14
mrboon
mrboon's Avatar
Drives: Speeeed
Just got a msg that mine has been sent should get here in spain in a few days, ill make an install video.
      12-15-2009, 12:17 PM   #15
twin turbo
twin turbo's Avatar
Drives: 2020 M340i xdrive
I have had the JB+ installed (at 100%) for approx. 7,500 miles. Car runs great and I can remove or reinstall the JB+ in about 2 minutes. Very easy in the Z4. Not as good as the JB3 for sure, but good power for very little money and effort. I have Bavarian Technic cable and have never found any hidden tuner codes on the ECU. I did have to have my fuel pump replaced, but I do not think it was related to the JB+. Happy tuning!
2020 BMW M340i xdrive
2016 BMW M4 (sold)
2015 BMW M4 (sold)
2014 Audi RS5 (sold)
2012 Audi TT RS (sold)
      12-15-2009, 12:33 PM   #16
Chuck76
Chuck76's Avatar
19
Drives: 2009 Z4 3.5i
twinturbo,
where does the pnp jb+ plug into? any dyno runs?
      12-16-2009, 02:50 PM   #17
twin turbo
twin turbo's Avatar
It plugs into the TMAP sensor just underneath the airbox. Very easy to reach on the Z4. I think there are instructions on www.burgertuning.com. No dyno runs. There is a dyno chart for the JB+ installed on a 335 with 93 octane on Terry's site as well. IIRC, it makes about 40hp and 50 lb/ft. of torque, very noticeable difference in power.
2016 BMW M4 (sold)
2015 BMW M4 (sold)
      12-16-2009, 05:29 PM   #18
mrboon
mrboon's Avatar
Drives: Speeeed
Hopefully i receive it soon, i will TRY to make a good installation video. It will be my first time on a BMW, so it might not be a very smooth video.
I did an ecu upgrade on my old audi a3, that was very easy.
      12-16-2009, 08:55 PM   #19
flpnout
flpnout's Avatar
Drives: 2010 Dinan S3 Z4-35i
2010 E89 Z4  [7.83]
Twin Turbo thanks for the PM about the JB+. I may decide to order that as well or wait for the Dinan flash. I plan to do the upgrade next year after the Christmas expenses.
2015 BMW i3 REX
      01-23-2010, 03:42 AM   #20
mrboon
mrboon's Avatar
Drives: Speeeed
I must say, having JB3 in my Z truly made it a different car. Running map 5 atm without any error codes, and the power is insane. It makes me laugh out loud every time i put my foot down
zpost
