New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      09-18-2009, 07:17 AM   #1
dcs2k
Drives: E92 M3
Juicebox3 in my E89 - dyno chart attached
Went in for a dyno today. Stock map vs map 5 on a JB3 on a otherwise stock car.
Numbers are whp on a mainline dynolog.
AF seems pretty rich after 5k rpm. not sure if a tune can solve that.
      09-18-2009, 07:51 AM   #2
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
Cool mod.
They may not had enough cooling on the front end of the car. Trying to find the Dinan vids on youtube where he was saying you can't hardly get enough air through the radiator to prevent the sensor from kicking and making adjustments to the a/f, timing, etc.
I'll post when I find it.
      09-18-2009, 11:35 AM   #3
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
Where is the chart?
      09-21-2009, 07:24 AM   #4
welbo
Drives: Z4 sDrive35
How about the torque gain?
Any overheating issue?
      09-21-2009, 08:42 PM   #5
BlueZ4AZ
Go SU
BlueZ4AZ's Avatar
Drives: 2009 Z4 sDrive35i
I see a misprint. The data sheet says 4 Cylinders.
      09-21-2009, 09:40 PM   #6
Alext
Drives: B M W
+48HP or so seems a bit low for a JB3 on map 5? Seems to be a big dip around 6000RPM, where the curve looks as though it should peak.
      09-22-2009, 05:37 AM   #7
dcs2k
Drives: E92 M3
guys seems like i was on a wrong map during the dyno run . 7 instead of 5. was advised to run on 5 again on the dyno as I do not have any supporting mods. Will do another dyno run soon and report back on the findings
zpost
