07-24-2009, 10:47 PM | #1 |
Rep 1,388
ECU upgrade for 535 at VF-Engineering: Dynos
LATEST RELEASE for 135/335/535 OEM STYLE ECU REFLASH
GIAC USA, (Irvine, CA) have just released their 1/3/535 - ECU flash upgrade. The software upgrade is electronically installed with no hardware components and uploaded into the stock ECU through the OBD2 port ! GIAC has been calibrating ECU software for the aftermarket for over 14 years and their reputation in the Porsche, Audi, VW and Bentley market speaks for itself. GIAC have been writing proprietary custom software for all VF-Engineering supercharger and turbocharger systems since Dec 2000. GIAC have been in the background of the BMW aftermarket since the late 90s with their NA tunes for the older E39 540 and E36 M3s. Their software powers our most popular kit to date : the VF stage3 E46 M3 supercharger taking power from 275 to 600whp on 91 octane, and now their 135/335/535 ECU flash will bring them to foreground! After 2 years of continuous testing on their in house 335 as well as many other models, GIAC engineers rigorously dis-assembled and re-calibrated the different versions of OEM software with the various anti-tuner defeat code using their own proprietary methodology. The GIAC software is designed to work on a complete stock to a fully loaded 1/3/535 using upgraded intercooler, bypass valves, exhaust etc. All testing is performed with 91 octane at the GIAC laboratory on their Mustang AWD-MD500 dyno cell. This allows them to perform road simulation to drag race type scenarios. Their extensive use of diagnostic equipment to monitor the vehicles critical sensors is part of the key to creating a reliable yet powerful software upgrade. GIAC programing laptop Programmer connected to OBD II port Below as an example for the E60 owners, we have tested an employees Dad's 535 Automatic. This car was dynod completely stock with stock exhaust on 91 octane on our in house Dynojet 224. Then the ECU was flashed with the GIAC software while the car was still strapped on the dyno. The car was then run on the dyno immedately after. you tube stock run- Below are the results: Peak power increased from 266 whp to 308 whp (at the rear wheels at 96 DegF - 535 Automatic - 91 octane) Peak torque increased from 269 wtq to 337 wtq (at the rear wheels at 96 DegF - 535 Automatic - 91 octane) Boost increased from 8.2 to 13.5 psi Max power increase: 62 whp at 4400 rpm Max torque increase: 74 wheel torque at 3100 rpm Remember this is an automatic on 91 octane ! power and torque torque and boost Manual transmissions have already been dynod to much higher levels. We will be posting some plots of manuals cars that we will be dynoing next weeks. |
07-26-2009, 01:37 PM | #2 |
Ninja
390
Rep 4,014
nice...any info on pricing...just to clarify,this ECU flash is undetecable correct/no tuner or manip codes thrown?
when will this be available?
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i Last edited by geneatals; 07-27-2009 at 09:52 AM.. |
