BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      03-16-2009, 08:20 AM   #1
shendrick
Drives: 08 e90 M3, 05 e46 zhp, 07 X3
Rear Differential Issues
My 2008 E90 M3 had it's 1200 mile service done and is now at 2,000 miles. In the last 250 miles it has developed what best can be called a groaning shudder in right turns that is slowly getting worse. The Dealer says that it is the rear differential and he will put a new different fluid in that should solve the problem. He reports that in some cases this solves the problem but if it doesn't they'll replace the differential. Question is, should I push back or not? What if the new fluid kind of works and delays failure of the diff until it becomes my responsibility? Anyone else have experience with this?
      03-16-2009, 08:30 AM   #2
shendrick
Just saw the other lengthy thread (Diff noise) on this - you can kill this thread. I will add to that one if I learn anything new.
m3post
