BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      02-14-2009, 09:30 PM   #1
moog55
moog55's Avatar
Drives: E92 M3
EDC malfunction a day after H&R Sport spring install
So I took my car in on Thursday to a very reputable shop to have them install my new H&R springs and spacers. I picked up the car and they said the procedure went very smoothly and it seemed fine on the drive home.
Friday, I drove to work and everything seemed fine as well, but today when I was running around, I got the error and it persisted the rest of the day.
Any ideas what the tech may have done or not done for this to happen??? loose connector maybe? i highly doubt that i could have ruined a shock in basically an hour's worth of total drive time since the springs were installed. i went over a few speed bumps in parking lots, but very, very carefully as i normally did prior to lowering my car.
i think the shop is closed for the weekend, but it would be good to see if any of you ran into this so i can give the tech/shop some ideas to follow-up on.
thanks.
      02-14-2009, 09:31 PM   #2
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
my guess is it's a loose connector
      02-14-2009, 11:03 PM   #3
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
+1 most likely loose connector
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      02-14-2009, 11:31 PM   #4
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Let us know what it turns out to be! hope its just the connector like other said.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      02-15-2009, 12:12 PM   #5
swamp2
swamp2's Avatar
Drives: E92 M3
As it seems you already know you don't need EDC compatible springs - there is no such thing. Both folks above are very likely correct you have a loose connector from the harness to one of the shocks/struts.
      02-15-2009, 10:30 PM   #6
moog55
moog55's Avatar
Drives: E92 M3
providing it's just a loose connector as all of us suspect, will the idrive error go away as a result of re-connecting the loose connector? for example, with the tpms errors, there is a way to reset the error so it goes away.
      02-16-2009, 12:05 AM   #7
schadenfreude
schadenfreude's Avatar
Drives: '09 E90 M-DCT M3
2009 E90 M3  [0.00]
Pretty sure that's what someone else said happened. Reconnected and it cleared.
Which shop did you use? Tru Line?
AiB LEDs///MS Filter///Hardwired V1///VentureShield///F1 Pinnacle 35%///IND Reflectors///BMW Performance Grills
      02-16-2009, 12:10 AM   #8
moog55
moog55's Avatar
Drives: E92 M3
I went to Group 2 (http://group2inc.com) on the recommendation of several other local E9x'ers in the area. They are a great shop with really knowledgeable techs. I'll give them a call tomorrow and hopefully get it back there in the next day or two.
      02-19-2009, 04:37 PM   #9
moog55
moog55's Avatar
Drives: E92 M3
just to follow-up on this, we were all correct in guessing it was nothing more than a loose connector. the embarrassing part was realizing that getting to the EDC connectors was as simple as popping the hood and lifting one cap to expose it. i thought the connectors would be accessible through the wheel wells.
the connector is pretty flimsy and poorly designed if you ask me, but in any event, it took a minute to fix and all is well now.
      02-23-2009, 07:07 PM   #10
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
I actually went to Group 2 with the BMW club on Sat and talked to Chris (I live in Magnolia and have been going to Group 2 for a while. Great bunch of guys). Since I had mentioned to Chris in the past that I may be interesting in getting H&R springs for my M3, he mentioned that he had just done one with EDC. I guess you are the guy!
So, how is the ride? Can you tell any difference vs. stock springs. What conditions is it better or worse?
Thanks much for the info.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      02-24-2009, 01:52 AM   #11
moog55
moog55's Avatar
Drives: E92 M3
yeah, Group 2 is great. i'll go back there for all my work in the future.
the ride is pretty nice. it's a little harsher than stock, but that's to be expected. i say that though in the context of driving around the shitty city streets of seattle. out on the highway, it feels completely smooth and balanced. i feel a bit more "connected" to the road on the highway as well.
as far as looks go, it completely changed the character of my car. it gets even more looks now than it did before. i also had H&R spacers put on at the same time too so that may have added to it. e92 m3s need to be dropped.
if you're considering new springs, i highly recommend the H&R sport. perfect drop, great feel and plays well with EDC.
      02-24-2009, 11:32 AM   #12
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Sounds like you are very happy. Can you post some photos when you get a chance. Better yet, hopefully we can get a Puget Sound E9X M3 get together soon and I can check it out in person ;-)
Thanks,
      02-26-2009, 01:25 AM   #13
moog55
moog55's Avatar
Drives: E92 M3
i usually go to the local meets and the next one is probably coming up. otherwise, i wanted to take pics last weekend, but ended up being too busy and then the weather has been shitty the last few days. i'll get some taken soon.
i am totally loving the springs and spacers.
      04-07-2009, 01:10 PM   #14
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
So how are the H&R springs behaving a couple of months after install. Any issue with EDC. How's the ride?
I am thinking of having Group 2 install some on my car.
Thanks,
      04-09-2009, 12:18 AM   #15
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
If you need help installing the springs or have any questions let me know. I installed mine myself back in January in my garage using hand tools. Very straightforward though a bit time consuming, but you do learn a bit about your car!
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      04-09-2009, 03:41 AM   #16
BimmerRob08
BimmerRob08's Avatar
Drives: 2008 M3, Space Gray
Does lowering the car with springs mess with the suspension "M" drive system settings? IOW, I I select comfort or normal or sport settings on the EDC, does it still work as intended? How much lower are the H&R springs compared to stock? I lowered my 93Aero Saab I had and ended up going with Koni shocks because there was so much debate over the struts being compressed 15mm would eventually beat the hell out of the shock system. Is this a problem with the M3's shocks?? Thanks,
      04-10-2009, 05:32 PM   #17
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Thanks for the offer. I have installed springs in the past. I think I am going to have Group 2 do the install this time though. I like these guys.
Did you install H&Rs. Are you happy with them? Chris at Group 2 thinks that the spring rate is only about 10 to 15% higher than stock so that is doesn't degrade ride quality much. Is this true? This would be what I am looking for. I like the current ride quality, I just want the car to sit lower.
Thanks,
m3post
