      04-06-2025, 11:01 PM   #1
aznbo187
Drives: E46 M3 | E82 135 DCT | I3
2012 X5D Deep Sea Blue Daily Tow Rig
Figured it's a good time to document my build for my 2012 X5D. It started out just being a daily that was good on fuel and had the potential to tow my E46 M3. Unfortunately, like every single car, started being affected by mod creep.
So the new title will be tow rig that can do mild off road stuff.
Specs
Deep Sea Blue
Ivory Interior
Sport Package
Audio
Mr12Volt MMI
Morel Integration Reference for fronts, rears and center.
Match Up W8 Underseat Woofers
Matchup 7 DSP
Matchup 1FX Mono Amp
Stereo Integrity SQL 12" Sub
Performance
Kassel 3" Downpipe & Midpipe
R90
Carven R-Series 3" Resonator
BMS Billet 4" Tips
Swirl Flap Delete
Bimmertune EGR Delete
Patek V2 Intake
Transmission Tune
Rev9 Intercooler
Clutched Harmonic Balancer
Exterior
30% Tint
Rhino Lined Grills (may go to chrome/black)
Brakes
Front
TBD - Are there any 2-piece rotors available?
Rear
EBC Rotors
Akebono Pads (will be replaced by Textar as these as squeaky as shit in cold weather)
Suspension
Powerflex Subframe Bushings
Remainder is stock at the moment. Will be going with a 1.5" spacer lift. Undecided on shocks yet, but it's between B4 and Koni FSD.
Wheels
Forged Rega Replicas
17x7.5 -5/-15
Nitto Terra Grappler G3
265/70/17
Etc
Curt 2" Trailer
Upcoming plans:
I think at some point it will get a turbo upgrade and SPD tune. Suspension will be gone through and lifted. Paint correction and deciding between paint matched black trim, or leaving it as is. Really want to swap out the sidesteps to something else. Upgrade the headlight projectors. Maybe some mild lighting upgrades.
Appreciate 7
      05-05-2025, 11:51 PM   #2
Muradi
The Don
Muradi's Avatar
Drives: E70 X5 35d/E93 328i Cabriolet/E46 330ci Cabriolet
Specs
Deep Sea Blue
Ivory Interior
Sport Package
Audio
Mr12Volt MMI
Matchup 7 DSP
Performance
R90
BMS Billet 4" Tips
Swirl Flap Delete
Patek V2 Intake
Transmission Tune
Rev9 Intercooler
Exterior
30% Tint
Brakes
Front
Rear
EBC Rotors
Suspension
Wheels
17x7.5 -5/-15
265/70/17
Etc
Curt 2" Trailer
Upcoming plans:
I think at some point it will get a turbo upgrade and SPD tune. Suspension will be gone through and lifted. Paint correction and deciding between paint matched black trim, or leaving it as is. Really want to swap out the sidesteps to something else. Upgrade the headlight [...]
By far one of the best 35d builds. Might br the best I’ve seen so far. You should post pics of the interior as well.
      05-13-2025, 10:59 AM   #3
aznbo187
Thank you! Will update shortly. Searching for a X5M carbon trim.
      08-16-2025, 01:50 PM   #4
aznbo187
Some recent updates.
MBD 35mm Lift Kit.
Bilstein B4 Front Shocks.
Bilstein Rear Air Bags.
Koni FSD Rear Shocks.
Lemforder front and rear sway bar links.
New suspension bushings.
EBC Greenstuff Front Brake Pads.
Zimmerman Front Rotors.
Replaced the rear pads with Textar.
IND Color matched reflectors.
Up next:
Morimoto XB LED Fogs.
New Front Upper & Lower Control Arms.
Considering spherical for thrust arms.
Brake flush. Diff flush.
      09-01-2025, 02:22 PM   #5
BrianM1256
Drives: 2009 x5 35d
I love the deep blue color and the lift kit! Do you have any pictures of the audio system upgrades?
      09-06-2025, 09:17 PM   #6
aznbo187
It's not much to look at right now, I ripped out the sub enclosure and will rebuild it to sit under the trunk cover.
The underseat woofers and door speakers are plug and play. I spent a good amount of time addressing any rattles and panel gaps with sound deadening. I would definitely recommend the underseat woofer upgrade - those were a good bang for the buck.
      12-31-2025, 02:57 AM   #7
aznbo187
Some more recent snaps from my road trip across the states. Drove from Arkansas to California without a hitch. Averaged around 19mpg with the tires and a fully loaded car. Very comfortable drive. Made a few stops with one of them being Moab, Utah and drove through Canyonlands which is an amazing and unreal showcase of dramatic landscapes. There were trails that cut through the actual mountains I didn't get to drive on, but maybe in the future.
      12-31-2025, 03:37 AM   #8
aznbo187
Some additional updates.
Took her out to a local California OHV trail called Rowher Flats in Santa Clarita. There were various difficulty levels and the X-drive did surprisingly well in even some medium technical trails. I wouldn't say it's something I fully trust or designed for slow crawling trails, but it didn't get stuck either. I went out with a friend in his GX and another in his Cayenne GTS.
Did not disconnect the sway bars and only lowered the tire pressure to about low 30's. Alibaba wheels so far as still holding on just fine with over 8k miles of cross-country, fire roads and mild off roading.
I've also installed 2 Vibrant Ultra-Quiet (3") Resonators where the muffler used to be. It has a full delete otherwise and this quieted it down in the cabin very nicely. It wasn't loud to begin with, but I recently have been on a stereo improvement journey and didn't want the exhaust notes to tarnish the sound quality that I'm working so hard on.
Also finished up the brake fluid flush and new front control & thrust arms. I went with Lemforder for both of the arms as I've read the Meyle HD arms were not good for this chassis.
Next up when it gets a bit warmer I plan on doing some paint correction and touch ups.
Interior wise, I'll make a new post but I've been updating all of the speakers, sound deadening and having fun with adjusting the sound processing via the matchup amp.
      04-16-2026, 01:06 PM   #9
sleepye21
Drives: e21
Very nice, did you have any rubbing issues with wheels at any point but especially when stock height?
