Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Health, Fitness, Martial Arts, and Nutrition
      11-19-2024, 01:32 PM   #1
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
rep range
What rep range do you prefer for adding muscle? 5x5? I’m trying to move from 4x10-12 to 2x10 + 2-3x6 based on the science aspect I’ve been learning about. But I’m sure there are some here who have already applied this range. What seems to work best for you for muscle?
Stage 2 BM3
Sounds pizzagatey.
      11-21-2024, 02:59 PM   #2
UncleWede
UncleWede's Avatar
I'm 58, and never looked like Jixer, so I have switched to 5x15 on lighter weights to just maintain enough strength to carry the 50lb chicken food bags on the farm
I was impressed last night. On the sliding squat bar, I upped it to 35lbs on each side.
      11-21-2024, 03:30 PM   #3
Wolf 335
Wolf 335's Avatar
Drives: 2007 E92 335i
It seems that every so often im seeing a new discovery in regards to muscle growth.
I think the key is consistent muscle confusion.
- Alternating between high reps lighter weight and then low reps heavy weight.
Another thing is that people end their set way too soon and dont excert the muscle.
      11-21-2024, 04:06 PM   #4
Hadden14
Drives: 2018 F80 M3 Comp
5X5 is the fastest way I have found to increase strength. There is some interesting literature about not going to failure (contrary to the meat head way I was trained) and instead maximizing the amount of reps you can complete at a reasonable weight with longer rests in-between sets.
      11-21-2024, 04:08 PM   #5
Pauldunlop13
Drives: M4 Convertible
May - Sept - 3-4 sets of 10 reps
Sept - current - 5x5 - all my weight went up significantly
Dec - Feb - I will switch to 3-4 sets of 15 reps - lighter weight
one issue of the 5x5, I got tendonitis in the first 2 weeks, because I jumped the weight up too much (hard not to, since I was only doing 5 reps)
but basically the plan is to rotate through these 3 ranges going forward
I also implemented the Deload week every 5 weeks - which I think helps with recovery of the joints and tendons
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition
2015 BSM M4 Convertible - 2018-2019
2016 228Xi - 2017-2018
2003 Acura RSX Type S 2003-2017
      11-21-2024, 04:09 PM   #6
UncleWede
UncleWede's Avatar
Variety of motion too, even if a subtle change. Hence preacher curls (wide or close) hammers, etc. On my squats, each time I changed direction and/or how wide my feet were spaced.
      11-21-2024, 05:44 PM   #7
floridaorange
Super helpful thanks!
Stage 2 BM3
Sounds pizzagatey.
      11-22-2024, 10:08 AM   #8
Wolf 335
Wolf 335's Avatar
This is key!
      01-24-2025, 09:42 AM   #9
floridaorange
Youre right on - this is great
Stage 2 BM3
Sounds pizzagatey.
      03-02-2025, 09:08 PM   #10
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://youtube.com/shorts/l3ViYswa97c?feature=shared
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      03-03-2025, 01:23 PM   #11
floridaorange
That guy is a mix of super obnoxious and really good info —- great info though
Stage 2 BM3
Sounds pizzagatey.
      03-03-2025, 02:03 PM   #12
xander_g
Drives: F95 X5M
2023 BMW X5M  [0.00]
Depends on who I'm working out with and what we're working on. I'm mostly relying on other people's experience as I can see the results of what they've been doing.
Example 1:
3 superset exercises(flat bench dumbbells', flys, curls) 4 sets total, 1min rest in between - 1st(warmup) - 15 reps, 2nd(working) 10-12reps, 3rd(max) 8-10reps, 4th(drop to warmup weight) - 8-10reps;
Example 2:
1 exercise(lat pulldown), 4 sets total, 2-3min rest in between - 10-12reps
Example 3:
1 exercise(flat bench), 4 sets total, 3-4min rest in between - 6-8reps, 1st(super light warm up. ie 55lbs) 2-4th(max weight ie 100lbs)
The first example is training with a buddy who's been training since he was 12, kind of a gymbro approach but solid progress in terms of building endurance
The second example is with someone who's has a more scientific approach and training for size/aesthetic
Third example is with my trainer who's is as scientific as it gets and primarily trains athletes.
When it comes to working out, I'm pretty much a noob and the reason I ended up in the gym in the first place, was because it was suggested by my physio to help rehab my back injuries.
      03-04-2025, 08:22 AM   #13
floridaorange
Originally Posted by xander_g View Post
Example 1:
Yes - this is fantastic, great post.
15, 12, 10, 8 is my rep range usually. It's always yielded great results. I don't have much more muscle to add naturally without adding more calories, which I don't want to do, so things are right on track at 45 and natural. Zero injuries and feeling very strong.
Stage 2 BM3
Sounds pizzagatey.
xander_g1169.50
