Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      09-18-2024, 04:34 PM   #1
IND-Distribution
IND-Distribution's Avatar
11162
Drives: G82 / G87 / G90
IND | MMX Performance Magnetic Oil Sump Drain Plug - S63
The MMX Performance BMW magnetic sump plug is a simple yet effective upgrade that can dramatically increase your engine's lifespan. As an engine wears, tiny metallic particles become suspended in the oil, accelerating wear each time you drive. Our magnetic sump plugs will help to separate these ferrous particles out.
There's no avoiding it, your engine's contact surfaces wear a tiny amount each time it runs. So, it becomes inevitable that tiny ferrous particles become suspended in the oil. They quickly make their way around your engine via the oil system for thousands of miles traveling over sensitive components such as your crankshaft bearings or camshaft caps, slowly contributing to increased engine wear.
Our magnetic sump plug has a large surface area magnetic end, which helps to catch metal particles. And of course, the harder your engine works, the greater the risk of this nasty metallic debris, meaning the greater the benefit of using our magnetic sump plug.
The MMX Performance magnetic sump plug is crafted from T6-6061 lightweight aluminum and is anodized in our trademark gloss black finish. It's supplied with a set of 5 sealing washers included (additional packs of washers can be ordered).
Product Details:
  • Fits S63 Engine; for F95 X5M / F96 X6M application fits Pre-LCI models only
  • Full OE plug replacement
  • M18 x 1.5 fitment
  • Protect and increase engine lifespan
  • Crafted from T6-6061 lightweight aluminum
  • Anodized in our trademark gloss black finish
  • Supplied with a set of 5 sealing washers
The MMX Performance Magnetic Oil Sump Drain Plug - S63 may be viewed at the following link to our online store:
https://ind-distribution.com/product...drain-plug-s63
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
