03-30-2024, 12:47 PM | #1 |
Rep 351
How to access rear caliper bracket E18 bolts
Hi. I was hoping to replace the rear brake rotors and pads of my 2011 50i. I had successfully done the fronts a couple years back. I could not, however, figure out any way to access the rear caliper bracket bolts. There is just no room there to get a socket in and to get any leverage. Any suggestions? I don’t have access to a lift — just a jack and stands.
I ended up just doing the pads since it was debatable if I needed rotors anyway at this point. But I would love to know if there are any great tips before I give up and send the rotors back. Thanks! |
03-30-2024, 03:38 PM | #2 |
Rep 3,073
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
I had a hard time getting the bolts off, but IIRC access wasn't a problem. Just couldn't get enough leverage. I used a jack to push up the breaker bar and that finally realeased them.
03-30-2024, 08:39 PM | #3 |
Rep 876
I think I removed the lower rear strut bolt, and moved the strut out of the way (and/or hub dropped low enough for access) for easier access. I don't recall this being a big hurdle. GL.
OH, use a jack under the hub for support and to make it easier to remove strut bolt.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
gadgetfreak2024223.00 |
03-31-2024, 07:37 AM | #4 |
Rep 351
I figured I would have to disassemble additional parts, but am not experienced enough to make the decisions about things like that.
03-31-2024, 08:03 AM | #5 |
Rep 876
It sounds like you were in there already, did you try long extensions w universal joints? It’s been about 2 years I was under there and don’t remember exactly how I did it, but again I don’t recall it being difficult. I took pix of my job and I see I have one w a breaker bar on the strut bolt, hence my suggestion. Post here if you get stuck.
I do recall needing a heat gun to more easily remove the old rotor.
2013 X5M AW/Blk
