01-26-2024, 04:36 PM | #1 |
Rep 175
Comfort Access mystery?
I have 2013 E70 30d with comfort access option.
My front right door (passenger) can be locked/unlocked with the comfort access door handle with the door open/ajar. On all other doors the lock/unlock feature only works with the door closed. It is driving me mad that I can't figure it out. I thought it was the door handle, so I swapped in another known working one and it is the same. I switched out the door latch to a new one as I thought it was a bad hall sensor in the door latch. No difference. Is there something I am missing here? A bad computer module? A coding option? |
01-27-2024, 11:52 AM | #3 |
Rep 905
Interesting..I checked mine and CA does not allow lock through the handle with the door open. This is the same for all doors. It could be a coded option...and maybe yours was coded for LHD?
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
01-27-2024, 01:51 PM | #4 | |
Rep 175
I might be imagining this, but it seems like the left rear door has the same issue. Maybe the wiring for the Comfort Access has a short between two wires? or two wires are switched? So it believes the front right door handle is the left rear and vice versa? |
01-30-2024, 02:53 PM | #5 |
Rep 175
Both the front right and left rear does this when it is able to lock/unlock with the door open/ajar.
It doesn't matter which other doors are closed or open. No error codes. Maybe I need an exorcist to get the little gremlins out of the car. Haha |
