      12-05-2023, 10:23 AM   #1
NJX5D
Drives: '12 X5D, '05 Excursion 6.0L
codes codes and more codes
Hey everyone,
on the way home from work last week my check engine light came on. my foxwell died so had to borrow an autofix for bmw. have a couple questions in general as well.
background:
-2012 X5d 130k miles
-stage 1 tune(don't know the tune, the original owner was suppose to send me the info but never did after the sale)
-just had an inspection and let the shop do an oil change about 2,200 miles ago
-had the battery tested in Aug, all numbers were as new. the only con is the age of the battery
-my CA door handles stopped working bout 2 years ago but it had never drained my battery so never bothered me and left a lone.
1. should i get another foxwell or protools or bimmerlink and bimmercode?
2. think its safe to delete the codes and drive to see if they come back?
3. should i force a regen? last regen bout 2,200 miles and 2 days ago. wonder if something was done at the shop to trigger this based off the mileage of last regen and inspection. i drive 500-1000miles a week
4. does my car still do regens(stage 1 tune)?
5. front pads/rotors replaced in Aug
6. should i disconnect the door handles?
Codes:
CAS
-A128 hardware rain sensor
-A103 Immobilizer bus fault
ECM
-4BDC DDE Fuel presupply, presupply control
480A DDE Particulate filter
4B91 Oxidation catalytic converter, plausibility
GWS
-A82E Interlock E fault
VGT
-54C6 oil wear
-55C6 message(wheel spin, ce)
DSC
-54E4A wheel spin plausibility rear right
-5F12 break pad wear, front axle brake pads
-5F45 brake fluid low
Instr
-A559 Instrument cluster supply was switched off(terminal 30g_f)
IHKA
-9C69 module PTC
CID
-A472 video connection:no LVDS lock
CA
-A06B Aerial, bumper
-502A097 not found
-502AB7 not found
-502A0C7 not found
TRSVC
-CAAI message(termials, Ox 130) error, receiver TRSVC, transmitter CAS
CCC-BO
-EICF actual configuration does not match specified configuration
MOST system
-A128 hardware, rain sensor
-A103 immobilizer bus fault
CAN
-A128 rain sensor
Thanks for the help!
