01-07-2023, 02:13 PM | #2 |
The Seeker
14204
Rep 3,427
I stopped doing pull-ups because of a slight shoulder injury they caused in 2019 at the age of 49. I still do dips, which are harder on the shoulders, but don't seem to have an issue with them at all. I'd suggest listening to your body, and even before that, figure out what you think you're getting from the exercise. I used to do pull-up's for back definition when I regularly maintained 12% body fat, but now I couldn't care less about back definition, so the risk isn't worth the reward.
In answer to your question I'd say it just depends on several factors. |
overcoil3081.00 Murf the Surf19289.50 |
01-07-2023, 02:49 PM | #3 |
Rep 779
You can do them for a long time if you have proper form, like do not fish-flop, keep tension in the back all the time, have proper grip, etc: I am almost 50 and never had injury doing them, since I started doing them properly.
01-07-2023, 02:53 PM | #4 |
Rep 671
I'd say never. I'd think motions with greater risk like Deadlifts a better candidate for removal. But as long as you can maintain proper form, even those should be fine at a modest weight. Snatches, though... now those are likely to get dropped sooner rather than later. A lot also has to do if you compete. Anything body weight I would think would be perfectly acceptable into old age as long as you stay relatively fit and and height/weight proportionate. All about them scaps for pull-ups.
floridaorange10369.00 overcoil3081.00 |
01-07-2023, 04:06 PM | #5 |
BMW Owner Since 1971
2276
Rep 1,422
Drives: 1964 700 Sport Cabriolet
Once you learn how to control your bladder you can stop the pull-ups and go to big-boy underpants!
17
01-07-2023, 04:12 PM | #6 |
Rep 7,228
Of course the older you get the harder that is to do. Might have to graduate to Depends.
01-07-2023, 04:19 PM | #7 |
Rep 2,681
Never. Pullups, dips, deadlifts, squats = for life!
To get back into any of these start with kettlebell swings, as your grip strength returns, you will find pullups easier. I like to do 10 pullups, 9 chinups, 8 pullups, 7 chinups and so forth until I get to 1 every other day no matter what. I'm 43 in 1 month. Read this: https://foreverfitscience.com/exerci...body-strength/ |
overcoil3081.00 |
01-07-2023, 06:34 PM | #8 |
Rep 5,580
01-08-2023, 06:20 PM | #9 |
Rep 139
OP why do you feel you need to stop? Injury? I'm 68 and pull-ups in some fashion (bar or rings) are part of my routine. You should never stop exercises unless you have an injury. You may not be able to do as many reps or as much weight but there is no reason to stop.
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
01-08-2023, 08:19 PM | #10 | |
Rep 5,580
Curious if people thought pull-ups was too risky over a certain age. Have stopped doing some exercise like heavy deadlifts and squats and think my running is better. |
floridaorange10369.00 |
01-09-2023, 09:11 AM | #11 |
Rep 834
I'll be 54 this year and have always incorporated 4 sets of narrow grip pull-ups at the beginning of my back training to stretch&loosen up and get things warmed up. I have a shoulder replacement so I always use strict form w all my movements
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
01-16-2023, 10:14 AM | #12 |
Rep 24
Drives: 2023 M4CX
Pull-ups or any other body weight exercise IMO is always a great option at any age. Also, I’m almost 48 and have made the decision a few years ago to discontinue placing anything heavy on my back. Suit case squats for me.
Esteban44848.00 |
01-16-2023, 11:15 AM | #13 |
Rep 7,228
That's how I do them as well. 68 this month.
Gratefulm472.00 |
01-16-2023, 12:08 PM | #14 |
Rep 538
57 here and I still do them. Altho I can't get four sets of 10 in anymore. Maybe 10 on the first set then lucky to hit three or four on the fourth set. It's a part of my rock climbing regimen.
What's killing me is I may have to stop running. 40 years of distance running may have contributed to some migratory arthritis in my feet. Still mixing up some cross fit, cycling, climbing and subbing elliptical for the running trails. I reckon if I make it to my 70's I'll have to settle into some low impact yoga to stay fit.
overcoil3081.00 |
01-16-2023, 03:39 PM | #15 |
Rep 7,228
Actually I think I do a ‘farmer’s squat’ vs ‘suitcase squat’ because I hold a dumbbell in each hand vs in one hand. Whatever it’s called. Lol
Gratefulm472.00 |
01-16-2023, 10:07 PM | #16 |
Rep 400
I still do pull-ups, but use one of the machines that lets you set it to reduce the weight you have to lift. It’s easy to take off whatever amount you need to be comfortable, and you still get the full arm extension down and a pull up that limbers up your back and shoulder muscles.
overcoil3081.00 |
01-17-2023, 02:58 PM | #17 |
Rep 2,681
If you never stop, you'll never have to stop.
If you do stop, once your over 45, start back by doing chinups only for a while. Do curls, using a dumbell and hammer curls, get your biceps engaged often, make sure your core is strong from planks and various types of situps, use kettlebells to get your lats and grip strength back, then pullups won't be nearly as daunting. |
04-20-2023, 08:09 AM | #18 |
10878
Rep 27,645
At first I thought the thread was going to be about pulling up to car meets I read the title and said interesting question, let me see what this thread and comments are about lol.
Pull ups, I do them 2 times a week on my back/Bicep days, its my first exercise 5x10-12. Im 40. I also play golf 4-5 times a week and do hot yoga 6 times a week so not sure if that helps or will eventually hurt . PS I also like doing farmers walks, someone told me years ago its a good idea to counter when you do a lot of pulls ups with them so I do. Not sure if its sound advice or not but so far so good
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
04-20-2023, 12:58 PM | #19 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Pullups are the god of back workouts. Even better with a weight vest
https://www.amazon.com/Aduro-Weighte...s%2C109&sr=8-8
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
04-20-2023, 04:36 PM | #20 | |
Rep 1,248
2024 M2
2019 M240i- Sold |
GOLFFRR10877.50 |
04-20-2023, 06:11 PM | #21 | |
Rep 3,926
I miss being in shape. |
04-21-2023, 07:28 AM | #22 |
10878
Rep 27,645
I do! Im a member at a club called the Alisal Ranch in Solvang and also La Cumbre Country Club in Santa Barbara.
JMcLellan2135.00 |
