12-13-2022, 11:04 AM | #1 |
Rep 106
X5 Lurches forward trying to idle forward after complete stop
Not sure if I have a transmission problem or a brake problem.
75% of the time whenever I am in D, come to a complete stop, and then let off the brake to idle forward the car lurches forward. The only way I can explain it is if you ever washed your car and your brake pads slightly rust to the rotor and it finally breaks free and lunges forward. Does anyone know if the brakes hold during a complete stop? The same symptom happens when I use the 'AUTO H' feature but not sure what is used to hold. No rough shifts or anything after the initial "lurch." Any insight would be nice, just trying to figure out which parts I should try to replace first....Throwing money at this car is my only hobby
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue 2006 E90 330i Silver - Donated after 410,000 miles |
12-15-2022, 05:40 PM | #4 |
Rep 61
Sounds to me like you may have a sticky caliper. Get it up on jack stands and go through the same motions of stopping all 4 wheels and see if one sticks when you let off.
AM. |
12-16-2022, 12:40 AM | #5 |
Rep 270
Drives: 2006 Z4 M Roadster
I'd suggest resetting the adaptives in the transmission using INPA or ISTA/D.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
12-17-2022, 06:28 PM | #6 |
Rep 1,564
Had issue with mine, turned out to be funky solenoids in transmission preventing the torque converter lockup from fully disengaging. Replaced solendoids and resolved all the issues. Lots of kits out there now to do this. Recommend you pickup the ATSG manual if you tackle yourself. Not a bad job but you must be meticulous and get everything right when you bolt back in the valve body
argento568.50 |
