BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Suspension / Brakes / Chassis / Spacers
      06-17-2022, 02:22 AM   #1
SkiFly01
SkiFly01's Avatar
Drives: '11 M3 comp pkg
FS: Ground Control Coil-Over conversion kit for EDC
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
Front Springs - GC150.64.77 (6/2.5"/440 LBS)
Rear Springs - 0800.250.0650 8"/2.5"/650 LBS
Installed on the car for a week and it felt amazing with the stiffer springs and the camber plates, while keeping EDC. Removed after one week and went a different route. When removed, one bearing for the top-hat camber plate was replaced from ECS Tuning with BMW part # 31331090613
Equip your E9X BMW M3 with this Coil-over Conversion kit specifically designed for M3's with EDC (Electronic Damper Control).
This spring kit gives you the option to customize the ride height of your vehicle. After several years of use in racing applications, Ground Control spring kits have been adapted for street use. Most other spring kits offer only one set ride height when installed. The Ground Control system's unique design allows for easy adjustment. Simply lift the corner(s) of the vehicle that you wish to adjust and spin the adjustable spring seat up or down to raise or lower the vehicle*. Ground Control spring kits are also designed to be used with either stock or aftermarket shocks. This kit includes camber plates that allow adjustment to approx -2.5°
-Kai
m3post
