11-24-2008, 03:41 PM | #1 |
Rep 299
Lowering springs Eibach / AC Schnitzer
I'm thinking about lowering my E93 M3.
Someone told me once AC Schnitzer is using Eibach springs. Is this true? Does anyone has lowered his car with one of these lowering springs? Pictures in combination with the optional 19'ers? Thanks in advance... |
11-24-2008, 05:01 PM | #2 |
Rep 17,017
I don't have confirmation that ACS uses Eibach for their spring kits but it's entirely possible as they outsource their exhaust manufacturing to REMUS.
Here are some shots of the standard Eibach kit installed on Technic's E90: We do have these in stock so let me know if you need assistance with a set! |
11-24-2008, 08:35 PM | #3 |
Rep 239
01-14-2009, 07:16 PM | #7 |
Rep 1,125
01-15-2009, 08:41 AM | #8 |
salivator
38
Rep 539
the drop looks to be similar. ACS measures their drop from the middle of the car where as Eibach measures the front wheel and the rear wheel.
Are these springs priced the same? |
01-17-2009, 01:04 PM | #10 |
Rep 1,125
01-17-2009, 05:40 PM | #12 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
The AC springs retail for 9XX and vendors sell them for around 800-850 plus shipping.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
01-17-2009, 08:24 PM | #14 |
481
Rep 8,828
Drives: SMB F83
Any thing that has AC Schnitzer stamped on it are more expensive anyways. I'm not sure if the spring rates are the same as the Eibach branded springs though. That might very well be the difference.
01-17-2009, 08:42 PM | #16 |
481
Rep 8,828
Drives: SMB F83
I say go with whatever you are comfortable with. Probably won't make much of a difference anyways. I went the AC Schnitzer route and will report back Monday after the install.
01-18-2009, 10:09 AM | #17 |
Rep 152
I am sure that you like the ACS as I hear only good things about them, but the price gauge for simply rebranding just kills it for me. GL
01-18-2009, 10:36 PM | #18 |
47
Rep 410
ACS springs not the same as Eibach
Hello guys,
I thought I would shed some light on this subject. ACS has their own suspension engineer on board by the name of Manfred Wollgarten. Manfred has been making BMW suspension set ups for over 40 years and is regarded as an expert in the field. He is also the test pilot for ACS and has tested all of his suspensions on the nurburgring during the R & D process. Over the years, ACS has partnered with many suspension manufactures (Eibach, Sachs, Etc) to build Manfred's set ups. ACS makes a contract with the suspension manufactures in order to insure that their R & D is only used for the manufacturing of the ACS product. There is a difference. ACS suspensions are world renowned because of Manfred's blend of track worthy handling, with real world streetablity. Manfred's latest suspension is the Racing Suspension for the E9X M3. It is a fully adjustable coil over set up with 20 position dampen control. He used an "upside-down" set up on the M3 for a number of reasons. This set up reduces unsprung suspension weight and can be adjusted easily from under the car. It is extremely robust and can handle uneven surfaces while promoting a long useful suspension life. I put this race suspension in my car and I can attest that it is nothing short of amazing. Here are some shots of the suspension and my car as it sits. Dampen control set to +13 front and rear and loving it. Last edited by FrankieP; 06-09-2009 at 10:01 PM.. |
08-16-2011, 05:59 AM | #20 |
Rep 639
bump
'11.5 SG E93/6MT/ALL BOXES CHECKED BLACK GRILL/BLACK SIDE GILLS/15% TINT/PAINTED REFLECTORS/SPACERS/ANGEL iBRIGHTS/20'' VOSSEN CV3/VINYL WRAPPED SHADOW LINE TRIM/ETS-POWER TUNE/ ///M-FLIGHT MEMBER |
