      10-20-2021, 03:32 PM   #1
TTV8M
TTV8M's Avatar
126
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
Torque Converter Upgrade Or Replacement
I'm looking for either an upgraded or custom billet torque converter. I reached out to revmax.com to see if they make anything custom for the
ZF 6HP-28X that's in this 2010 X6M (donor car 2011 x5m)
VAC recommended also looking into replacement clutch packs.
Anyone ever source out custom torque converters?
Thanks.
'10 X6M
'08 Cooper S
      10-21-2021, 03:46 PM   #2
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
Update: http://www.jakesperformance.com/ is willing to take a look at the factory TC. Im sending it in next week. Stay tuned.
'10 X6M
'08 Cooper S
      10-22-2021, 09:52 AM   #3
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
triple disk x5m converter
Found another opportunity from cdsftw.com
They're working on a triple disk X5M custom torque converter. Won't be finished until December 2021. I am following up with them in January 2022.
They also state:
"Most of our bigger power ZF customers are swapping to 6r80 stator support and input shaft. These components are stronger than the ZF pieces, so you might look into doing this."
'10 X6M
'08 Cooper S
      10-23-2021, 04:34 AM   #4
Dawgz
2022 M4 Comp Xdrive
1024
Drives: 2022 M4 Comp Xdrive
They also state:
Very nice
Level 10 sells kits
      10-26-2021, 10:03 PM   #5
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
thanks, ill call them tomorrow and see if they support the 6hp-28x trans
Originally Posted by Dawgz View Post
Very nice
Level 10 sells kits
'10 X6M
'08 Cooper S
      10-27-2021, 09:54 AM   #6
T-Dubbs
Coal Troll
151
Drives: '14 F10 535d
Perhaps Rod Sutphin can help...
He sells TQ converters for diesel x5's
https://sutphintuning.com/
My hybrid burns Diesel & Oil
deleted F10 535d
TTV8M126.00
      10-29-2021, 07:57 PM   #7
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
levelten.com is the best. they can work on any transmission or torque converter. i sent my TC up to them today. $1000 and they will rebuild it to support 1000hp. naturally i wont be that high on hp nor can i launch this frankenstein when im done.......... but just saying
also, they offer a full transmission and tc upgrade to support 1000hp for $7000 just in case u do wanna launch it all the time.
'10 X6M
'08 Cooper S
      10-29-2021, 08:08 PM   #8
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
thanks, ill check them out and will probably use for the trans tune
'10 X6M
'08 Cooper S
      11-04-2021, 09:25 PM   #9
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
just got the torque converter back from levelten.com. super fast. UPS delivered it to them this past monday.....and i received it back today (thursday).
not much to look at, new coat of paint on the outside but definitely looks new down the input shaft. guaranteed to handle 1000hp. too bad I wont know how it runs for another few months. still waiting on the block from VAC
'10 X6M
'08 Cooper S
      11-08-2021, 08:09 PM   #10
Dawgz
2022 M4 Comp Xdrive
1024
Oh u went with the 1000hp one. I know they have 700 and 1000.
Any pics? Did you tell them anything specifically or just told them you needed the upgraded for your zf6hp28x?
      11-08-2021, 08:15 PM   #11
Dawgz
2022 M4 Comp Xdrive
1024
Yea they upgraded my trans and mechantronics unit.
Did everything except the Torque converter.
      11-21-2021, 09:59 PM   #12
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
Just told them the Trans number like u mentioned and yes I said round up on the hp, so went with the 1000hp tc. I was too cheap to spend the 7k for full trans n tc for 1000hp
'10 X6M
'08 Cooper S
      11-21-2021, 10:06 PM   #13
TTV8M
TTV8M's Avatar
126
2010 BMW X6M  [0.00]
TC from levelten.com
'10 X6M
'08 Cooper S
      11-22-2021, 01:01 PM   #14
Dawgz
2022 M4 Comp Xdrive
1024
Sweet!
      08-05-2022, 05:07 AM   #15
markhenry7846
Drives: Baleno, Alto
Revmax is proud to offer 4L80E Torque Converter on the market which have:
Billet 1 piece CNC machined front cover assembly
Billet TCC lockup apply piston
Upgraded Stator sprag
Integral rear anti balloon plate
High performance single disc high carbon lockup clutch assembly
Studs replaced by grade 8 bolts (Ford models)
TTV8M126.00
