07-28-2021, 10:04 AM | #1 |
Rep 20
(HELP!) e70 X5M Coolant Hose Quick Clip
I was working on my X5, had to remove the coolant host from the IC and the quick clip broke.
Dealers tell me I need to purchase a new hose. That's crazy. Does anyone know where to locate these quick clips for the IC coolant hose? I have looked all over and can't find it. I attached an image of the left IC and the hose. Can anyone guide me to finding a quick clip? |
07-28-2021, 03:27 PM | #2 |
Rep 630
Do you mean the metal clip that slots into the plastic to lock the hose onto the nipple? If that broke (seen people lose those, not really break them) you'll likely have to find one at a pick n pull style junkyard if you don't want to buy a new hose. Dealer is right, no part number for those metal clips.
07-28-2021, 06:11 PM | #3 |
Rep 101
That happened to me too on my old 330i however mine flew out and disappeared into oblivion when I only had a parking lot to work in. Never found it.
Take one off the other hose and go to the hardware store and buy a similar gauge steel rod. Then if you have a vise and pliers you can bend up a new one for about $5. Nothing terribly special going on with those it’s just a retaining clip. |
07-29-2021, 10:54 AM | #4 |
Rep 20
It took a lot of time, but I think I located the quick clips. Some of these should fit.
Dorman 800-808 Radiator Hose Clip, Pack of 2 Dorman 800-807 Engine Coolant Hose Clip Direct replacement - this HVAC heater hose retainer clip matches the fit and function of the factory part on specified years, makes and models Ideal solution - this clip is a reliable replacement for an original part that is missing or has failed due to fatigue Durable construction - this part is made from quality materials to ensure reliable performance and long service life Trustworthy quality - backed by team of product experts in the United States and more than a century of automotive experience Ensure fit - to make sure this part fits your exact vehicle, input your make, model and trim level into the Amazon Garage |
07-31-2021, 02:30 AM | #5 |
Rep 357
Drives: E70 X5M
Happened to me on the bottom of the expansion tank. Was taking the bottom hose off and the clip vanished.
Got myself a nice $200 clip from the dealer that came with a free hose. Lesson learned.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
07-31-2021, 08:32 AM | #6 |
Rep 101
I’d do a new hose as well because I’d look at it as “might as well take this chance to replace it.”
But when I was younger I didn’t always have the luxury of waiting on a part. Sometimes you gotta Get it fixed before work Monday morning. Here’s a quick video on how someone bent one up. https://m.youtube.com/watch?v=FgfHDeb6m2s |
08-02-2021, 07:26 PM | #7 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
So typically the dealer is right. Those clips come with the connector or in this case the hose. Sometimes if your friendly with the dealer they’ll just give you one. Or order the hose how much can it be?
08-02-2021, 07:28 PM | #8 |
Rep 1,146
Drives: F10 550i
P.s. a lot of those metal clips aren’t meant to be pulled. You push them in, and they release so no chance of going boing. I had to learn that the hard way with a map sensor. However sometimes is easier to pull them with a pick. But instead of a pick, use forceps….. that way you won’t loose it in the future.
