05-26-2021, 12:10 AM | #1 |
Rep 84
4x4 Shop Canada 10.25" Android CarPlay Music "Skipping Issue"
Hi Everyone. I've been working on an issue on and off for the past 2 months, and have yet to find a solution. I could use some help.
I have the a 3 month old 10.25" Qualcomm Snapdragon Android 10 Head Unit with wireless CarPlay that I bought from the 4x4 Shop Canada. It has 4G RAM + 64G ROM (8 Core) - 4G/LTE capability. My problem is when playing music over in CarPlay, over any streaming service like Spotify or Apple Music, or even playing music downloaded to my phone from those services, the music will randomly "skip" like a scratched CD. It sometimes will happen every 15-20 seconds, and other times it will go for 30-40 minutes with no issue. When it is happening, which is often, it's irritating enough that I often will switch the music off, which is very unfortunate given music is half the reason (other reason is GPS) that I wanted CarPlay. Does anyone have a solution? Or better yet, has anyone purchased this exact unit and NOT had this problem? I've read many people say they have the issue, and have yet to hear anyone say they don't have the issue. Small sample size though, so looking to hear more people's experience with this 4x4 shop unit. Thank you everyone in advance for your help/thoughts. |
05-26-2021, 01:43 AM | #2 |
Rep 60
What phone do you have? I had a Galaxy A51 that did exactly that with my bluetooth connected earphones. Problem was worse in busy areas where wifi and other bluetooth users were about. Replaced the phone with a Huawei P3 and the problem went away.
05-26-2021, 01:46 AM | #3 | |
Rep 84
Were you using CarPlay somehow? A 4x4 shop unit? What apps were you playing music from? |
05-27-2021, 06:05 AM | #4 |
Rep 60
This was with bluetooth headphones, so was just suggesting the phone itself could be to blame rather than the headunit. Some of these headunits have a bluetooth aerial which might be worth checking...
I play music via spotify so I dont stream from the phone to my headunit. |
06-01-2021, 12:23 PM | #5 |
Rep 12
Here are a few things to try. I haven't had this issue with my unit so far but try the below steps and see if it helps. I purchased my unit from AVIN. I would also reach out to 4x4 shops support team and see if they have any reports from other users experiencing this. They might have a fix.
1. Go into Bluetooth settings on your phone and disable the ‘Media audio’ option for your car’s Bluetooth device. You can also try disabling ‘Contact sharing’. 2. Try disabling Battery Optimization for the Bluetooth and Android Auto apps 3. Don’t automatically join free WiFi networks. Try disabling WiFi before you connect to your vehicle. 4. Turn Off location tracking 5. Turn Off Bluetooth scanning 6. Try Clearing the app cache for your music or podcast app as well as the Bluetooth app could resolve the issue On my unit, I can select vehicle Bluetooth or Android Bluetooth and I selected Android Bluetooth. If you don't have wireless CarPlay try a different USB cord. Most of the time you are sharing Bluetooth bandwidth like sharing contacts and hands-free calling etc... These can also cause issues Try these one at a time and move to the next if it doesn't work. Keep us posted. Last edited by BMWHoochie; 06-01-2021 at 12:35 PM.. |
06-02-2021, 08:16 PM | #6 | |
Rep 84
JDAURIA733.50 |
06-07-2021, 10:16 PM | #7 |
Rep 84
Update: The new firmware did not solve the issue. Has anyone else had this same "music skipping issue" while using CarPlay, on their android head unit? If so, did it ever get resolved? I have found many threads online about this issue, but no solution. It's left me wondering if playing music over Wireless CarPlay actually works without skipping for anyone? I do not have a wired option with this unit.
08-08-2021, 10:37 AM | #8 |
Rep 84
following up here: Wondering if playing music over Wireless CarPlay actually works without skipping for anyone? ( it doesn't for me, it skips often). I do not have a wired option with this unit.
08-08-2021, 06:24 PM | #9 |
Rep 876
FWIW, I have a loaner car and wireless CarPlay works flawlessly, so it's not my phone.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
08-09-2021, 09:53 PM | #10 |
Rep 337
https://support.avinusa.com/hc/en-us...ound-skipping-
Someone at AVIN did tell me the built in Wireless CarPlay feature is unreliable and they recommended using this adapter instead https://avinusa.com/autoplay-usb-ada...nd-a-auto.html Last edited by 03Saleen; 08-09-2021 at 10:04 PM.. |
Jon_G13.50 |
08-11-2021, 12:42 AM | #11 | |
Rep 79
Hope this helps… |
08-11-2021, 03:17 PM | #12 |
Rep 19
I have had the unit from 4x4 shop for a few years now and have always had issues with the audio. I bought the usb dongle that has both wired and wireless CarPlay (wired I would say is smoother). Both still tend to skip (usually when the phone is being used for nav, etc) but furthermore the quality isn't great even when not skipping (very slight static noise).
My fix to the problem is getting my CarPlay set up, then swiping up on my iPhone to see my control center and selecting the music audio output (I'll attach a picture of what I'm talking about). Then I select my BMW's Bluetooth which works much better; instead of the aux coming from the android unit. The final result is I can use CarPlay and my BMW Bluetooth at the same time.
2011 BMW X5 35i || M Performance Package || BMS CAI Sequential LED Rear Bumper Reflectors LED DRL's with Signal |
08-18-2021, 11:04 PM | #13 | |
Rep 84
08-18-2021, 11:06 PM | #14 | |
Rep 84
Hmm. I will try this. Thanks. |
08-19-2021, 08:13 AM | #15 |
Rep 876
UPDATE, still in my loaner vehicle, but the last two times out I've had ONE skip moment in each ride. Appears my deduction that it's not my phone may be flawed. Sorry, I don't have any other tangible helpful info...
2013 X5M AW/Blk
08-21-2021, 09:49 PM | #16 |
Rep 84
I've tried 3 different phones with mine... each with the same issue
08-28-2021, 10:53 PM | #17 |
Rep 4,325
I bought the shop4x4 unit for my e93.
It does the same things sometimes. Sounds like yours is worse. Mine will skip a few times. It either goes away or I tune it out after a while. The phone connection will sometimes glitch and disconnect too. Maps sometimes lags too. I think it’s just the actual unit at this point. It will never be as good as factory Apple play. |
01-18-2022, 12:34 PM | #18 |
Rep 84
UPDATE: After 6 months of trying firmware updates ( I was close to giving up), the most recent firmware update from the 4x4 shop FINALLY fixed the audio skipping issue. This was as of the firmware released in October. I can update the exact firmware build number upon request later when in the car. I was waiting til now to make sure it worked on my old iphone and my new iphone pro 13, and i'm happy to say the music skipping issue has been 100% resolved at this point across all phones.
For reference, in the past I had tried the old firmware with many phones, (4x4 always blamed my phone, SMH) and it never worked on any phone I paired. It now works perfectly though on all phones after the October firmware release. |
01-18-2022, 12:44 PM | #19 |
Rep 300
Did 4x4shop send you the updated software, or was it something you were able to download yourself from another source?
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR? |
01-29-2022, 04:09 AM | #21 | |
Rep 1
Question for you, SpaceGrey_e70, when you say, "getting my CarPlay set up," what exactly are you doing, pluging your iPhone into a wired carplay/android usb cable from the glovebox? And what iPhone model? I plan to get the AVIN unit (haven't yet), and will likely order it with both wired and wireless CarPlay options, so I have some flexibility. My thing is this: I want to control CarPlay through the iDrive or touch screen, BUT, I want to send the actual audio to my upgraded DSP Amp in the back, that has BT 5.0, or HiRes usb input available. So far, I haven't been able figure out if this is possible. You post is the first this I've seen that sounds like my plan IS possible. From what I understand, BT 5.3 or so allows sharing the audio to more than one destination, so yeah, are you using a wired, or Bluetooth connection to the Carplay, while you send the audio to the car's bluetooth? |
10-19-2023, 09:54 PM | #22 |
Rep 1
Has there been any updates on the audio issues? Do they support usb audio now? Or have the newer units gotten better with the audio quality? I really want to upgrade my screen but I am too scared considering the audio is so poor for a lot of people.
