02-02-2021, 08:54 PM | #1 |
Rep 16
2007 X5 - Playing music through aux
I just purchased a 07 X5 4.8i, im trying to figure out how to play music through the aux, i had no problem bluetoothing the phone for calls, just cant figure out the aux, i get no sound
Any ideas how to get music to play from my ipod Last edited by 604BMWX5; 02-04-2021 at 10:49 PM.. |
02-03-2021, 06:25 PM | #2 |
Rep 1,777
When your phone connects via BT, you sometimes need to select it and make sure the music/audio box is checked. (Configure Phone).
**Nevermind** you were asking about AUX
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
02-04-2021, 09:11 PM | #3 |
Rep 16
I have been trying to play music through the aux setting but i get no sound, the options i get are aux/rear, could it be i need some kind of software update
02-05-2021, 12:55 PM | #4 |
Rep 60
My option is Aux Front and the jack hole is in the centre console near the phone cradle...
There is also a USB port there, and that works with a usb stick, but not with a phone. |
02-05-2021, 07:48 PM | #5 |
Rep 16
I also have a aux port in my arm rest, no usb though.
The only option on my command screen shows aux/rear i do have a dvd in the rear but the jack for that shows headphones Could my aux in my armrest be broken, is this common, any ideas how i can play music through my ipod would be appreciated |
02-06-2021, 06:44 PM | #6 |
Rep 16
Figured it out, looks like previous owner left me with an aftermarket cable which never worked with my iphone
08-02-2023, 05:40 AM | #8 | |
Rep 16
Wondering if there is a maximum size USB stick that is supported, I have a 16GB Plugged in and I get nothing when I select AUX, doesn't appear to read the USB and appear on the CCC? Or should I try the iPhone to 3.5mm Audio jack to see if that works |
08-02-2023, 06:40 PM | #9 |
Rep 905
Is the USB formatted to FAT or FAT32?
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
08-06-2023, 11:41 AM | #11 |
Rep 905
Sorry, wasn't clear, I actually meant it needs to be either of those...I had the same problem until I reformatted to one of those...I am using my USB now, I can pull it and check it if needed...
2013 X5M AW/Blk
08-12-2023, 10:27 PM | #12 |
Rep 16
I tried the 3.5mm AUX socket with an adaptor on my iPhone, that did not play anything on the CCC, I think the USB/Aux module maybe faulty?
