      07-23-2020, 08:24 PM   #1
Latinzai
Dominican Republic
Drives: BMW E70 X5 V6 2009
Exclamation My E70 won't start after a failed update to DME/DDE
Hi, guys. I really wish you could help me with this one
I was trying to update my modules using WINKFP, starting with the DME/DDE (Engine) module. I followed the steps described in this video. However, when I clicked the Prog. ZB-Update button to start the coding, the program froze for about 1-2 minutes, then an (very long) error related to access denied popped out.
After closing the program, I found that I messed up: the engine cranks, but wouldn't start.
MY SETTINGS BEFORE THE UPDATE ATTEMPT:Name:  E70 IDENT (2).png
Name:  E70 USER INFO (2).png
After the update the DME/DDE module is not listed anymore.
When I tried to flash again to see if that'd work, I get the following error messages:
Another important facts:
  • This is an E70 X5 xDrive 2009
  • The key was plugged in when the update took place. Ignition was OFF.
  • Used a K+DCAN cable with Windows 10
Thanks in advance for the help!
      07-23-2020, 11:15 PM   #2
TwinSnailz
TwinSnailz's Avatar
78
Drives: 2011 X5//M
At this point, try locate your old ZB dme number and attempt to try it again with a battery charger(hi amp) hooked up. Dme is very sensitive with juice power.
Did you flash any other module before the dme? I would’ve test it on some uncritical module before the dme.
      07-24-2020, 06:12 PM   #3
Latinzai
Dominican Republic
Exclamation
Hi TwinSnailz!
I did not flash any other thing before. Last thing I did was to code the battery using NCSExpert but that was long ago.
These are the previous settings:
ZB part no.: 7602220
ZB Number: 7603150
This is the ZB Number I attempted to update to: 8609178
The old one (7603150) is not listed here:
How can I find it?
      07-26-2020, 09:38 AM   #4
TwinSnailz
TwinSnailz's Avatar
78
Drives: 2011 X5//M
Try get a hold of an older daten file and reload it to winkfp. Manually enter the old zb number.
When you updated the last one, did winkfp choose it for you?
      07-30-2020, 10:54 PM   #5
Latinzai
Dominican Republic
Hi TwinSnailz !
I was table to get the vehicle working by doing the following:
1. Charged my battery with a stand-alone charger. It's a 80ah/990CCA battery.
2. Turned on the ignition.
3. Plugged the K+DCAN cable in the OBD port.
4. I deleted some error codes using Dr. Gini, but I think this was not necessary.
5. Opened WinKFP and selected Comfort -> Choose Custom File -> ECU: MSV80 -> ZB: 7617234 -> Done -> Program.
It flashed in about 2min or so. After that, the vehicle started and worked like charm. Apparently it was the lack of power that made it fail.
A million times, thank you!
I hope this thread can help others, too.
Autobacs1462.00
      07-30-2020, 11:36 PM   #6
TwinSnailz
TwinSnailz's Avatar
78
Drives: 2011 X5//M
Awesome glad it worked out !
      12-09-2020, 01:00 PM   #7
Karar.fares@gmail.com
Drives: 07 x5
Originally Posted by Latinzai View Post
Hi TwinSnailz !
i updated my DME now my car won't start it only cranks , the battery is charged fine , what should i do help
