      07-04-2020, 10:30 AM   #1
Tractorguy77
Drives: Bmw x5
2012 X5 diesel reduced power with lots of codes
Hello, happy 4th!
A couple days ago the 2012 x5 diesel got the first reduced power msg with roughly 130k miles on the clock. Lots of codes, 13 to be accurate:
46F9
4507
4BDC
4862
48DC
4B82
4C83
4370
44DD
3F25
3FF0
4865
4530
I checked on carbon build up, see image. There is some... i have no reference if it a lot of not.
How do I start diagnosing the issue? any leads?
Cheers!
H.
      07-04-2020, 12:04 PM   #2
sunny_j
sunny_j's Avatar
238
Drives: 2012 X5d
You can start by writing out the descriptions for each code...
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      07-04-2020, 03:07 PM   #3
Tractorguy77
Drives: Bmw x5
ok. here is what i found...
Seems to be related to the EGR. With all these codes, how do I go about testing? What is a good place to start?
At first I thought it may be vacuum related. When I turn on the car I can see the valve at the EGR cooler and turbo control move. Would that point to the vacuum system being intact?
46F9:
reducing agent active tank temp sensor open
4507:
Exhaust-gas recirculation, control deviation
4BDC:
DDE: Fuel presupply-pressure control
4862:
Air system, air to EGR mass flow, plausibility
48DC:
Boost pressure sensor, plausibility
4B82:
Exhaust-gas recirculation-rate control, control deviation
4C83:
Exhaust backpressure before exhaust turbocharger, plausibility
4370:
Exhaust gas return-rate control, control deviation
44DD:
3F25:
Charge air hose monitoring
3FF0:
Air mass measurement
4865:
4530:
Charging pressure control, control deviation: Charging pressure too low/positive control deviation
      07-04-2020, 05:10 PM   #4
Thecastle
Drives: 2022 G30 M550i
You have a leak in the egr system. It’s either one of the dpf Pressure sensor lines burned through, a cracked egr cooler or a plugged egr valve. Less often it’s a bad maf and pressure sensors.
You also have a bad scr tank. The heater can be replaced by a toureg scr tank heater for a big cost savings.
      07-04-2020, 06:04 PM   #5
Tractorguy77
Drives: Bmw x5
Thecastle, thank you very much! Would you be able to point which one is actually leading to the reduced engine power problem? I am looking to get this done first.
I looked at the erg cooler and cannot see any leaks, no fluid and no sote around it either. Are there other signs I should watch for?
      07-06-2020, 06:04 PM   #6
JDAURIA
JDAURIA's Avatar
833
Drives: F31 MSport
2016 BMW  [0.00]
Isn't the SCRA tank covered under extended warranty? You are just outside the 120k mile but within 10 years. Maybe a dealership will go out on a limb for you (goodwill).
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
      07-10-2020, 05:33 PM   #7
grapes11
Drives: 2012 BMW X5 35d
Codes
SCRA is tank covered under extended warranty? 10 years 120k from in date of service .
      07-12-2020, 07:52 AM   #8
Tractorguy77
Drives: Bmw x5
Thank you for all the responses! Last week I ordered a set of vacuum hoses to be prepared, those arrived yesterday. This morning I went and checked the exhaust gas pressure line which seems to look ok... at least to me. When I started the car I was surprised to not see a warning on the dash. After driving it a bit it showed up when I went up a hill and went into reduced power mode. Is this fault always intermittent?
      07-12-2020, 03:28 PM   #9
sunny_j
sunny_j's Avatar
238
Drives: 2012 X5d
The EMP hose may look fine but I'd remove it and see if it's clogged
Build Thread
      08-15-2020, 03:10 PM   #10
Tractorguy77
Drives: Bmw x5
Got it figured out... was the map sensor. Replaced in less than 30 minutes and limp mode gone, however, still the following codes left:
1) 4BDC
2) 46F9
The last one is obvious. How about the first... could a clogged fuel filter trigger it?
POBEP603.00
