      04-27-2020, 06:00 PM   #1
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
JDNY516 35d Journal
Back in the X5 fold again!
This is my 4th X5; two E53 iS models and one E70 35d
2011 BMW X5 35d
Black Sapphire Metallic (475)
Nevada Cinnamon-Brown (LUEZ)
Sports Package
Rear Heated Seats
Rear Climate
Heated Steering Wheel
Running Boards
One-Owner
93k Miles
Options I wish it had: Ventilated Seats, Heads up display, Style 214
Options I am glad it does not have: Comfort Access, 3rd row seating!
OEM+ Plans:
[ ] Software Tune (Probably DINAN since its $250 plug & play)
[ ] Install Tow Hitch (OEM)
[ ] Rear Cargo Lift Bracket/Strut Kit
[ ] Wheel change from style 335 to 214, 333, or 336
[ ] OEM Fender Flares
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[X] Clean/Condition all Leather Seats
[ ] Rear Brake Service
[ ] Oil Service
[ ] Fuel Filter replacement
[ ] Cabin Filter replacement
[ ] Transmission Service @ 100k
[ ] Inspect windshield cowl centerpiece
[ ] Update CIC Navigation Maps to 2019/20
Only pictures I currently have, and one last picture of the M3!
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      04-27-2020, 10:48 PM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
Looks clean! Nice choice. Look forward to your build...
JDAURIA725.00
      04-28-2020, 04:55 PM   #3
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Maintenance goodies arrived. Fuel filter, DEF fluid (to have on hand), Oil filter, OEM motor oil.
Vehicle in for warranty service: NOx sensor code popped over the weekend. Glad for that 10 yr /120k mile warranty!
Received the tow hitch parts this afternoon as well, having a local indy shop do the installation end of this weekend or next week. Order the rear cargo lift bracket from rbryantaz , Thanks! And ordered rear rotors and brake pads for quick rear brake service.
      05-09-2020, 03:02 PM   #4
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
05.09.20 - Emissions, Rear Cargo Latch, Upgraded Maps. Next, tow hitch install this upcoming week. Hoping to knock out rear brakes, fuel filter and oil service as well.
OEM+ Plans:
[X] Rear Cargo Lift Bracket/Strut Kit
[ ] Wheel change from style 335 to 214 or 336
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[ ] Oil Service
[X] Inspect windshield cowl centerpiece
[X] Update CIC Navigation Maps to 2019/20
If anyone has a lead on a set of style 214s let me know!
      05-10-2020, 08:37 AM   #5
argento
argento's Avatar
538
Drives: 2013 X5M
Thanks for posting your trunk pic! I've been wondering if my cargo carpet was properly installed and this gives me a baseline. If you're going to change the cabin filter, might as well replace the microfilters at the firewall in engine bay, $0.02. Super easy, there are two filters there and when you buy oem or otherwise, they come as a pair.
JDAURIA725.00
      05-15-2020, 02:42 PM   #6
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
05.13.20-05.15.20: OEM Hitch and wire harness installed! First Oil Service Complete. 96,000 miles
OEM+ Plans:
[X] Install Tow Hitch (OEM)
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[X] Oil Service
[ ] Differential Fluid Service (front and rear)
[ ] Transfer Case Fluid Service
I need to get better about taking some pictures of progress, but I figured most of you know how an oil change goes so it wasn't worth taking photos. Old motor oil was super dark, I went with OEM 5w-30 diesel since it's real cheap (83-21-2-466-457).
Added differential and transfer case fluid service to the list. Already picked up the parts, just need to find time to get under the vehicle again and somehow obtain this small 14mm hex tool that is needed. Part listing below for anyone who needs it:
Part Number Part Name
07-51-2-293-972 Synthetic Gear Oil Saf-Xo 832514
33-11-7-525-064 Drain Plug
83-22-2-409-710 Dtf 1 832514
Hitch install was done at local indy shop that I use for my E90 M3. They did a great job, super quick. Already did a 1.5 hour tow (~2,500 lbs two horse trailer, empty). Averaged about 20mpg! I'll get a picture next time it's hooked up. In addition, I will most likely be adding a brake controller as well.
      05-16-2020, 12:54 PM   #7
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
05.16.20: Rear Diff Fluid change. 96,000 miles
OEM+ Plans:
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[X] Oil Service
[X] Differential Fluid Service Rear
[ ] Differential Fluid Service Front
Used a $10 walmart pump (https://www.walmart.com/ip/Quicksilv...-Plug/17165291) Worked phenomenally - screws on, pumps the entire bottle. No need to sit there and squeeze the bottle. I did all this without raising the vehicle, I just did it on the ground floor on my back. A little tight but it's do-able.
      05-16-2020, 02:16 PM   #8
argento
argento's Avatar
538
Drives: 2013 X5M
Not wasting any time! Thanks for the tips...
      05-17-2020, 04:21 PM   #9
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
One of the main purposes of buying the 35d. Can't wait for 20in wheels and extended fender flares to go on...
      05-19-2020, 03:28 PM   #10
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
05.19.20: Front Differential Fluid Change, Transfer Case Fluid Service, Rear Brake Rotors & Pads Service, Fuel Filter Replacement - 96,000 miles
OEM+ Plans:
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[X] Rear Brake Service
[X] Oil Service
[X] Differential Fluid Service Front
[X] Transfer Case Fluid Service
[X] Fuel Filter replacement
Successful maintenance afternoon. Was able to get some lift access at a buddies shop. While he worked on the rear brake service, I knocked out the fuel filter replacement, transfer case fluid change and front differential fluid replacement. Everything was very straightforward, even a novice DIYer like myself never felt uneasy. Most of the undercarriage trim pieces are held on by 8mm, 10mm bolts, and fasteners.
Front differential fluid service: the front driver wheel needs to be taken off and there is a trim piece that needs to be removed as well. There is a fill and drain plug for the front diff unlike the rear where there is just one plug.
Fuel Filter replacement: straight forward, (2) 10mm bolts hold the filter in place on a mount. Remove the clip off the electrical harness and the front hose is secured by a screw tie-down (if yours was never previously replaced then it will have a one-time use clip that needs to be cut off). Previous owner replaced the fuel filter at least once, so there was a screw down fastener. Old filter was dated 11.2013! Glad I changed it out
Transfer case fluid: again straightforward with a 14mm hex (very short). Drain and fill plugs. I replaced all plugs with new OEM plugs (total of 5: two for front diff, one for rear diff, and two for TC). Reset adaptations with autologic software.
Rear brakes service: new rotors and pads. Purchased from RockAuto for $150 total shipped.
Next: sourced some used good condition all weather mats. My driver mat is all worn and I don't have a rear cargo mat - this is a must for it's daily duties. Also sourced an E60 M5 cluster for parts. I will be doing a little cluster retrofit to add a little OEM+!
      05-19-2020, 03:49 PM   #11
argento
argento's Avatar
538
Drives: 2013 X5M
Are the gas lines quick connect or is there a lot of fuel spillage?
      05-19-2020, 04:04 PM   #12
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Decent spillage. Especially out of the filter once it is out. Good to have a oil pan handy.
      05-20-2020, 05:11 PM   #13
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
It’s happening!
      05-21-2020, 02:52 PM   #14
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Mounted, what a difference. OEM flares arrive next week.
OEM+ Plans:
[X] Wheel change from style 335 to 214 or 336
[ ] LUX H8 AE
[ ] Upgrade Cluster
Maintenance Plans:
[X] Oil Service
      05-21-2020, 09:27 PM   #15
argento
argento's Avatar
538
Drives: 2013 X5M
I am in awe of your diligence...well done! Looking GREAT
JDAURIA725.00
      05-22-2020, 02:43 PM   #16
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
05.22.20: Cluster Mod!
OEM+ Plans:
[ ] LUX H8 AE
[X] Upgrade Cluster
Sourced a cheap E60 M5 cluster off M5board. Utilize the front shell (plastic and silver gauge reds) + red needles from the M5 cluster. I decided against swapping over the white LEDs (for now). We'll see how much I like the OEM orange. Fairly straightforward process.
- (4) T10 torx screens to remove the back half of the cluster
- Push down on (4) clips to remove the front half of the cluster
- Needles can be pulled straight up and out
Nyc Dito112.50
      06-01-2020, 10:53 AM   #17
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
06.01.20 - All maintenance is up to date! Transmission Service completed this morning. Fluid, gasket, sleeves, megatronic adapter, reset adaptations etc OEM Extended Fender Flares installed as well
OEM+ Plans:
[ ] Software Tune (Engine and Transmission)
[X] OEM Fender Flares
[ ] LUX H8 AE
[X] Upgrade Cluster
Maintenance Plans:
[X] Oil Service
[X] Transmission Service
Next: New Tires. Deciding between Conti DWS06 or Michelin A/S3 NSpec
Nyc Dito112.50
argento538.00
      06-02-2020, 12:05 PM   #18
tmvatlanta
Drives: E39 M5, E70 X5M, 90 Z32TT, 360
2010 BMW X5M  [0.00]
Nicely done.
How much is the tow hitch kit? How to update the Nav software (I haven't searched yet)?
2000 E39 Dinan M5
2010 E70 X5M
1990 Straman Z32TT
2001 Ferrari 360 Spider
1996 Mitsubishi 3000GT Spyder
      06-02-2020, 01:42 PM   #19
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Originally Posted by tmvatlanta View Post
Nicely done.
Hey Tam
Tow Hitch Kit I got from the dealership for just under $400. That includes everything you need to install (hitch and wire harness) - BMW of Fairfax
Update navigation maps: https://www.xbimmers.com/forums/show....php?t=1716225
      07-02-2020, 05:49 AM   #20
Letsgo
Drives: 2011 BMW X5 35D
How many liters did the rear diff, front diff, and transfer case take?
      07-02-2020, 09:12 AM   #21
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Front/Rear Diff - 1 Liter/each (OEM Fluid)
Transfer Case - 1 liter (OEM Fluid)
      07-07-2020, 12:26 PM   #22
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
07.07.20 - Week long trip complete. Flawless experience - diesel mpg distance is incredible on long trips. Adding a few items to OEM+ and Maintenance
OEM+ Plans:
[ ] LUX H8 AE
[ ] OEM Spare Tire Kit
Maintenance Plans:
[ ] New set of tires: Michelin Pilot All Season 4 (275/315)
[ ] Replace Steering Wheel Trim Switch
[ ] Oil Service @ 101k
[ ] Replace Front Brake Pads (OEM ones, dust wayyy too much)
