BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wash, Wax, Detail, Cosmetic Maintenance & Repairs
European Auto Source (EAS)
      09-09-2008, 02:43 AM   #1
L~R~G nor cal
Perfection Is In The Details
Drives: 06 E90
2006 325i  [0.00]
Detailing Perfection: 2001 GMC Sierra C3
Hey guys! Sorry I have not been posting lately. Between school and my girlfriend, I have not had enough time for a proper write-up for my details. I have been surprisingly busy and have now been receiving many return customers. Well from the get-go I knew this detail was going to have a great turn-around so I felt a write-up was calling.
THE DETAIL
Well the truck is a 2001 GMC Sierra C3. The truck as never had paint correction and has not had protection for over a year. For the first 80,000 miles the truck had seen many drive-through car washes and in the last 50,000 miles has seen good washing techniques. So as you can guess the paint was in bad shape. Also because of the harsh chemicals from the drive-through car washes, the trim had lost a lot of color and had become dole. The truck has also been driven up the Lake Tahoe countless times therefore the undercarriage had pounds of sand and dried salt caked to the surface. I will illustrate the pictures as much as possible throughout the post.
I was working very hard and was lazy with the pictures from correction to the final product and missed a couple of steps in-between, but you will still be able to see a huge difference.
Enjoy and thanks for looking!
Jared
*Exterior Detail Only*
BODY WASH
Honda Gas Powered Power-Washer
Foam Lance Foam Cannon
(2)Zymol Wash Sponges
(2) Buckets
P21s Total Auto Wash (Pre-Soak)
Chemical Guys Citrus Wash Clear (Main-Wash)
Chemical Guys Water Spot Remover
Chemical Guys MF Waffle Weave Drying Towels
DOOR JAMS
Swissvax Wheel Brush
WHEEL WELL/TIRE WASH
Tire Brush
Wheel Well Brush
WHEEL WASH
P21s Wheel Gel (Main-Wash)
CLAY
Special Yellow Clay
Chemical Guys Extreme Slick Synthetic Quick Detailer
PAINT CORRECTION
Menzerna Power Gloss
Menzerna Super Intensive
Menzerna PO106ff
2000 Grit Wet-Sanding Paper (Only On Certain Areas)
CCS Yellow Pad
CCS Orange Pad
CCS White Pad
Chemical Guys Polishing Pad Conditioner
Alcohol/Distilled Water (To Remove Polish Oils)
Green 3M Masking Tape
Flex Tool XC 3401 VR
Hitachi High Speed
Chemical Guys MF Fluffer Towels
PROTECTION/LSP
WINDOWS
Einszett Glas Polish
Lusso Glass Polish
WHEELS AND ALL OTHER METALS
Swissvax Autobahn
Megs App Pad
Costco MF Towels
WHEEL WELLS/TIRES
Chemical Guys Fade 2 Black
Costco MF Towels
PLASTIC TRIM
Chemical Guys Trim Gel
Costco MF Towels
Megs App Pad
BLACK METAL TRIM
Costco MF Towels
Megs App Pad
HEAD LIGHTS/TAIL LIGHTS/ THIRD BREAK LIGHT
Pluxes
Chemical Guys Fluffer MF Towels
[B]DOOR JAMS[B]
Chemical Guys Jetseal 109
Megs App Pad
PRE-WAX
Chemical Guys VB-408
Megs App Pad
LSP
Megs App Pad
FINAL WIPE DOWN
Optimum Instant Detailer & Gloss Enhancer
First up was the wheels, wheel wells, and tires. As you can see the interior of the wheel was caked with years of build-up and needed a lot of work. I started off by soaking the wheel, wheel wells, and tires with P21s TAW. Next I brushed the tires and wheel wells and then rinsed off everything with the power washer. After I was happy with how the wheel wells and tires turned out, I started with the wheels by giving them a good soak with P21s Wheel Gel. I let the Gel sit for 10 min and then started brushing them with my Ace Power Stick hooked up to my drill. Finally I brushed the face of the wheel with P21s Wheel Gel with my Swissvax wheel brush and gave everything a heavy power-wash to make sure all the soap was off the surface.
For the door jams I gave them a good soaking with P21s TAW and then brushed them with a different “door jam only” Swissvax Wheel Brush. The finished with a good power wash.
Here is what the paint looked like before the wash.
The car received a good soak of P21s TAW to de-grease the entire truck and then was power washed.
Next was the foam cannon and wash steps. I used the two bucket method with two Zymol Wash Sponges. It had some water-spots so I mixed some Chemical Guys Water Spot Removier in with the wash to take care of them.
I used the special yellow clay (you know what it is) and here is what ¼ of the truck looked like.
I started with the smaller trim. The upper is not polished, and the lower is.
Another angel
Here is a 50/50 of the hood
And another
This was a tough area the needed wet-sanding.
Before
After:
Here are some reflection shots after a quick foam to get the polish oils off. NO LSP.
For my last steps I decided to go with products that have never let me down. I used CG VB408 to make sure all the polish oils were off and to add a bit of depth and then used CG Jetseal 109 and my last step. Once the CG Jetseal was al wiped off I came back with OPT QD to finish it off. For all the plastic trim I used CG Trim Gel, for the wheels and chrome/metal trim I went with SV Autobahn, and lastly for the dressing I dressed the wheels with CG Fade2Black along with the wheel wells. Keep in mind that in these pics I did not wipe the tires off yet therefore they look a bit un-even. Lastly I polished the glass with Z1 and Lusso glass polish.
2006 E90 SG-Dinan Ram Air Intake-Dinan Throttle Body-Dinan Exhaust-19' Hyperblack CSL's-15/5 tint-Matte Black Grills-M3 Spoiler Lip-Amber Delete-Smoke Side Signals
      09-09-2008, 03:08 AM   #2
s1cke92
s1cke92's Avatar
Drives: E92 M3
hey your in sacramento? how much do u charge for INTERIOR And EXTERIOR Work all done together. hook me up haha
      09-09-2008, 04:35 PM   #3
L~R~G nor cal
Drives: 06 E90
2006 325i  [0.00]
PM sent
m3post
