      09-07-2008, 01:37 PM   #1
rockmed
Drives: none
Anyone try clocking 0-60mph on their V6 or V8 ?
      09-07-2008, 01:53 PM   #2
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Nope, but the 3.5 I have moves like a bat out of hell. I am sure it has a lot more than 300HP, more like 340, as I think I can get well under 6 seconds.
The V8 must be in M3 range.
2011 535i
2008 VW GTI
      09-07-2008, 02:02 PM   #3
shenard
Drives: '09 X6 50i AW
2009 BMW X6 50i  [0.00]
It is not quite that fast. I know you love your X6 and it feels fast to you but those times are not realistic. X6 50i is low 5 range (5.2-5.4) and X6 35i is low to mid 6 second range.
Once tuners like Dinan and Vishnu come out with with tunes for the 50i then it will probably be M3 fast if not slightly faster. The X6 will certainly get you a lot more attention than the M3.
My 50i feels about the same as my previous Lexus IS350 but with more torque which is definitely needed to move 5,000+ lbs.
      09-07-2008, 02:23 PM   #4
rockmed
Drives: none
I just finished the 1200 mile break in period and tried 0-60 on the 50i and it did about 5.6sec. Perhaps it's the weather (about 100 degrees) that is affecting the performance or perhaps it's because it need a few more accelerations to reach optimal performance. I'll try it again in a few days.
By the way the car does not feel like there is a turbo in it. No noticeable lag and feels closer to a naturally aspirated V8.
      09-07-2008, 03:41 PM   #5
m3_p0wer
United Arab Emirates
16
Drives: BMW X6
i did some runs with my xdrive35i and the best i got 6.5 other runs i got 6.7 , 6.8 i ran with bro x5 its way faster !!! ...
      09-07-2008, 05:04 PM   #6
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Which one was faster?
2011 535i
2008 VW GTI
      09-07-2008, 05:37 PM   #7
m3_p0wer
16
Drives: BMW X6
the x6 is way faster man i even gave him a head start !!
soon i will try with my bro with 2008 cayenne S this 1 will be interesting
because the cayenne pulled on x5 like the x6 but the x6 pulled harder than the cayenne at low speed due to tourqe i think but the cayenne pulls at high speed so i guess it will be so even stay tuned i will post the results i am sure i will win this 1
      09-07-2008, 07:07 PM   #8
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
What size wheels you have on the X6? And was DSC off?
2011 535i
2008 VW GTI
      09-07-2008, 10:19 PM   #9
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
Inline 6.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      09-07-2008, 10:24 PM   #10
Year's_End
Year's_End's Avatar
Yeah, if you're talking straightline speed it should match the M3.
Thing is, weight and drag play a large part in the overall equation. At low speeds, a chipped X6 will have a large torque advantage, but the M3 will have a large weight advantage. Also, at high speeds the X6 will have a greater amount of horsepower, but its huge frontal surface area will create a lot of drag.
It'd be interesting. Just don't throw curves into the mix, hahaha.
      09-07-2008, 10:50 PM   #11
shenard
X6 50i certainly has ALOT of drag. It is amazing how quickly the speed drops down when you let off the accelerator. If I was going 60 and let off the accelerator in my old Lexus IS350 it was coast and stay around 60 mph much longer than the X6. I would guess that by the time the Lexus goes from 60 to 50 the X6 would probably be at closer to 40.
No complaints. The X6 is SO MUCH MORE FUN TO DRIVE!!!
      09-07-2008, 11:00 PM   #12
x5mmm
x5mmm's Avatar
Drives: E70 X5 4.8i
fifth gear said that 5.0i 0-60 in 4.8 seconds!!! 0-62 mmm in 5.0-5.1 !!!
      09-07-2008, 11:09 PM   #13
rockmed
Drives: none
According to Road & Track, they clocked 4.8 by: "Disable traction control
and engage sport mode. Load the torque converter to about 2700rpm before releasing the brake pedal and allowing the transmission to handle the shifts for you."
Isn't that bad for the brakes and/or engine?
      09-07-2008, 11:34 PM   #14
Year's_End
Year's_End's Avatar
It's not horrible for the car if you don't do it that often.
Also, R&T (as well as many other mags like C&D) use 1 foot rollouts for their 0-60 numbers. The car probably hits 60 in the low 5's in a true 0-60 test.
      09-07-2008, 11:36 PM   #15
Year's_End
Year's_End's Avatar
Yeah, I bet it's more fun!
Also, I don't know if that's how you can determine drag completely. Gearing, the weight of the flywheel, and other things can factor into coasting deceleration other than drag.
How stable is the car at speed? I'm talking like 100+ here. Does it feel like it's getting pushed and swayed a lot?
      09-08-2008, 05:37 AM   #16
m3_p0wer
16
Drives: BMW X6
i had the 20 wheels inch ,, and DSC was on
      09-08-2008, 10:23 AM   #17
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
Shenard, I think you are also experiencing engine brake. Try to shift into neutral and see what a difference it makes. Just remember that on a BMW, you can only shift back into drive if you apply breaks! So don't try this in mid traffic with other drivers behind you
On my other cars, I used to shift into neutral when I was approaching an intersection with lights that were about to change to red or were red. I would shift back into drive once it changed to green and apply the accelerator. The first time I tried that on my wife's xDrive version BMW, it let me shift into neutral just fine, however it did NOT let me shift back into drive. I had to stop the car and shift back into drive. By now I figured out that I can shift into neutral and shift back into drive if I am decelerating by applying the breaks and just before I lift the foot off the break, I shift back into drive and then I can accelerate again. I don't do this very often anymore, at least not as often as I used to. It used to help a LOT in reducing the gas consumption (better gas millage) on my other cars!
2009 750i individual | Citrin Black Metallic | Platinum Merino Extended Leather | BMW Individual Composition Package (includes Sport Package) | Dynamic Handling Package | Multimedia Package | Technology Package | Executive Package
http://www.7post.com/forums/showthread.php?t=234432
      09-08-2008, 11:30 AM   #18
miktrebla09
Drives: biped
http://www.roadandtrack.com/assets/d...T_BMWX6_dp.pdf
pretty quick!
      09-08-2008, 12:14 PM   #19
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Originally Posted by miktrebla09 View Post
cool thanks for the info.
The question I have ( and I've brought this up before) is the non-US version tuned different so that you would notice it in performance? (noticed the European Spec designation)
      09-08-2008, 02:15 PM   #20
Herms
Drives: '15 M235i
Not good if you do it too often, just as dropping the clutch all the time on a manual isn't good. It's a must though for the step cars with the turbos. Can't get a decent time on the 335 either without boosting first.
I'm not sure about the x6 getting to M3 speed range. The M3 has already shown test numbers as fast (fastest I've seen is 4.1, though I usually go with edmunds since they seem to inflate less, and they got 4.3) or faster than the M5 with its 500hp, so I just have trouble seeing a car weighing more than a 1000 lbs more than the M5 getting much faster than mid 4's. turbos are deceptive though, always feels like you're going faster than you are. if you asked me most times, I feel like the 335 is faster than the M3, though every test would disagree with me.
'07 e92 335i (sold)
'08 e90 M3 (sold)
'15 M235i
      09-08-2008, 03:08 PM   #21
Year's_End
Year's_End's Avatar
Modern cars don't use any gas when coasting in gear.
      09-08-2008, 07:49 PM   #22
xDrive50i
xDrive50i's Avatar
If you watch the current gas consumption gauge on most non-turbo BMWs, it will tell you a different story.
