BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      08-29-2008, 06:25 AM   #1
Leg
Drives: E92 M3 V8 Alpine White
Post track day brakes question
I did Croft ast Sunday and the brakes held up just fine. Driving home they brakes were fine too (65 miles).
Whilst they are still performing fine they are now making a humming noise (I say now, this was Tuesday, I havent used the car since). All of the diagnostics through I Drive say all is well (green).
Im gonna pop the wheels off to look at the pads, my question was are the I Drive readings reliable and what is the likely cause?
E92 M3, Breyton GTS 19s, black and carbon all over
Factory Mini John Cooper Works 211bhp
MK Indy R track car (road legal) 300bhp+ per ton, sequential box
VW Tiguan 4x4
      08-29-2008, 11:03 AM   #2
sfbimmer13
Original Bavarian Heritage
sfbimmer13's Avatar
Drives: 2008 E92 M3 DCT
after my last track day (Laguna Seca) I noticed that I melted the pads and the rotors have a lot of pad material bonded to their surfaces. I had an incredible shimmy when braking, so I replaced the rotors, pads and flushed/replaced the break fluid with Motul 600 - the check control can only tell you when your pads are worn (sensors), but does not provide any information beyond that
2008 E92 M3 M-DCT - Sparkling Graphite - Fox Red - Tech Package - Premium Package - Moonroof - Enhanced Premium Sound - HD Radio - iPod USB interface - PDC - Remus Race Exhaust
      08-29-2008, 03:22 PM   #3
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
I also got some pad transfer on my rotors after the track, the symptom being some brake shimmy. I'm going to drive it a while to see if it wears off, if it doesn't get better I'll get the rotors replaced. I did not experience any brake fade during the entire 3 day weekend.
Brake Ducts seem like the appropriate fix for this in the future. I hope someone develops them soon.
SFBimmer is correct, Idrive only measures brake pad wear, it's not going to give you any indication of problems with vibration in the brakes.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      08-29-2008, 03:51 PM   #4
Leg
No vibration or shimmying, just a humming noice when braking. Wierd.
VW Tiguan 4x4
      08-29-2008, 05:31 PM   #5
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
probably pad materiel/
all you with a shimmey - dont waste good rotors and throw them away. have them lathed a minimum amount and take off the pad materiel.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      09-01-2008, 01:38 AM   #6
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
don't mean to thread jack, but how did your breytons hold up? or did you use OE wheels?
      09-02-2008, 09:39 AM   #7
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Turning the rotors on a lathe might not solve the shimmey problem. It might work if it is simply a matter of uneven transfer of pad material, but if parts of the rotor have gone through some kind of change in material properties due to overheating, that might go deeper than the surface and removing a tiny bit of material off the surface would not change anything.
This has happened to me twice now. The first time, it went away in a couple of weeks. The second time, things are getting a bit better after a week, but we'll see, which suggests it might be uneven pad material transfer. Would using track pads help?
      09-02-2008, 10:54 AM   #8
skierman64
skierman64's Avatar
2011 BMW Z4  [0.00]
I'm hoping my shimmy goes away as well.
Yes, track pads would help as they are more resistant to the heat and won't melt to the hot rotors.
      09-02-2008, 11:23 AM   #9
sfbimmer13
sfbimmer13's Avatar
just ordered Pagid Yellow RS 19s from Turner, since I will be in Laguna Seca for 2 days this weekend - I will post the results after I have used them.
      09-02-2008, 12:10 PM   #10
lucid
lucid's Avatar
Great! Keep us posted please.
      09-02-2008, 06:28 PM   #11
Leg
I use the OEM 18s for track, the Breyton 19s are for road use.
VW Tiguan 4x4
      09-02-2008, 10:10 PM   #12
sayemthree
sayemthree's Avatar
597
track pads - for sure!!!
m3post
