BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      08-28-2008, 02:44 AM   #1
kennethcho1337
Drives: public transit
brake rotors
do the OEM brake rotors hold up well on the track? no cracking issues? and also are the rotors a 2 piece setup or are they single piece?
      08-28-2008, 12:03 PM   #2
sfbimmer13
Original Bavarian Heritage
sfbimmer13's Avatar
Drives: 2008 E92 M3 DCT
no cracking issue, however they warp quite easily - I have done 3 track days and the car is in the shop now to get new rotors and pads...
not sure what you mean by 2 piece setup?? There are 2 ventilated discs per side check here:
http://bmwfans.info/original/E92/Cou...4/ill-34_1423/
2008 E92 M3 M-DCT - Sparkling Graphite - Fox Red - Tech Package - Premium Package - Moonroof - Enhanced Premium Sound - HD Radio - iPod USB interface - PDC - Remus Race Exhaust
      08-28-2008, 01:03 PM   #3
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
They are a two piece design. An aluminum hat with the disk connected by pins that allow for thermal expansion while reducing heat transfer to the hub.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now.
Why, yes. I am an abrasive bastard.
      08-28-2008, 09:58 PM   #4
kennethcho1337
R8 brake rotor = same design as M3 brake rotor!
About the warping, are single piece rotors easier to warp?
      08-28-2008, 10:13 PM   #5
consolidated
consolidated's Avatar
205
Drives: F80 M3
2 piece rotors are supposedly more resistant to warping, not less. Although they don't transfer as much heat to the hub the design is allow the disc material to expand independently from the carrier. What most diagnose as a warped disc is usually uneven pad material transfer due to pads exceeding their temperature range or incorrect bedding-in procedure. I've done this myself a few times.
      08-28-2008, 10:41 PM   #6
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Are you absolutely sure you have warped rotors? They should not warp that easily. My brakes develop a slight vibration toward the end of the track day, but it goes away after a couple of weeks of driving, which makes me think the issue has to with the pads or something else. This has happened to me twice now.
      08-28-2008, 10:52 PM   #7
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Is the rotor and pad replacement covered under warranty with track use?
      08-28-2008, 11:03 PM   #8
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Depends on your dealer, judgement call. Some people have had goodluck, others no.
edit: Not a brake expert, but unless your pulling up your hand brake after some hotlaps or really really pushing them hard find it hard to believe that they warped.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      08-29-2008, 12:56 AM   #9
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
I'm sure they gotta be a bit suspicious if you come in for this service every 4000 miles. I wonder what the limit is...
      08-29-2008, 07:58 AM   #10
lucid
lucid's Avatar
They won't keep on replacing your rotors at 5000 miles intervals. They would most likely do it once at that rate. Over the 4 years, it is not uncommon to get 3 or so replacements.
      08-29-2008, 10:52 AM   #11
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
Please tell me that you don't use your E-brake when you park your car after lapping sessions. I assume that you don't, but I have seen it too many times.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
      08-29-2008, 11:08 AM   #12
sfbimmer13
sfbimmer13's Avatar
no not absolutely sure, however when they replaced them they said that the rotors where shot...how would I actually find out for sure if they are warped - I kept the old rotors?
as others have said already it really depends on your service manager...this time I offered to pay for the replacement since I know that I have cooked the brakes...next time it is on BMW tap
nope
      08-29-2008, 12:35 PM   #13
lucid
lucid's Avatar
They would need to be mounted and rotated while being measured with a sensitive probe for deflection/uneven surface. I don't know what the spec is for these rotors, but we are probably talking about in the region of 0.001".
The rotors can be glazed due to overheating of local areas, which changes the characteristic of the metal and causes uneven friction across the surface of the rotor, which results in vibration. The first time that happened to me, it went away after a few weeks of driving as I mentioned, but it might very well not, in which case you need to replace the rotor.
      08-29-2008, 12:46 PM   #14
sfbimmer13
sfbimmer13's Avatar
thanks for the comprehensive answer - since I already replaced the rotors I am not going to obsess over it
      08-29-2008, 05:41 PM   #15
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
If the OEM rotors are two piece, does BMW just replace the disc or both the disc and hat when replacing the rotors under warranty.
      08-30-2008, 02:29 AM   #16
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
they are two piece floating roters with an aluminum hub hat and an iron disk, they replace the entire disc unit at one time.
however a lot of vibrations from the track are not always due to warping but due to brake pad material melting to the rotor. if so it will wear off and go away after a few thou miles, the only way to tell is to but the brake rotors on a lathe.
two pc. rotors should resist warping better than a one peice rotor (a single pieceof iron, hub and disc. )
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      08-30-2008, 10:23 PM   #17
ace996
NASA/PDA Instructor
ace996's Avatar
Drives: E92M3
These issues sound pad related...wrongpads for the track. Ive had the material buildup on the rotor issue on other cars and they always went back to normal after a week of normal driving, although I left the race-pads on until they cleared the rotors.
"Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task."Μολὼν λαβέ!!
      08-31-2008, 02:51 PM   #18
sayemthree
sayemthree's Avatar
597
x2
m3post
