09-11-2019, 10:38 PM | #1 |
Rep 269
(cold) Start up RPM
I've noticed that on normal start up rpms jump to about 1200 or so before coming down to idle. Usually same at cold start but they stay there for a few seconds. However at other times i noticed that on normal start ups the rpms jump to around 1700-1800 rpm. Any one know why? (n55 2011).
09-12-2019, 04:42 AM | #2 |
Rep 78
This is normal operating procedure for these vehicles. I believe it's to warm up the catalytic converter to make it work better/quicker.
If you don't like it, try MHD tune or something similar and you can delete the cold start idle. |
09-12-2019, 01:25 PM | #3 |
i'm just saying
5767
Rep 2,634
its normal of course..
when you try to start the car, modern cars check the air temp and many other parameters as well.. starter only cranks the engine up to 100-150rpm.. from that point ECU sends signal to have rich air fuel ratio to pick up the rev and keeping it away from stalling again.. rich air fuel mixture is safer for gasoline engines especially in first moments to heat up the engine in a linear way for not damaging the engine itself.. higher idle allows the engine to run without knocking with rich AFR when timing of ignition is being set differently in warm up phase.. things get more spicy in colder temps cause petrol gets thickened and to vaporizing it duration changes.. when combustion chamber is already in optimal temp this problem no longer exists.. in California those extreme conditions dont exist but in Lviv it does as you know.. for catalytic converters parts.. there is an emission test called cold start test.. i dont remember the exact timing of how long engine should be turned off prior to the test but its a different story.. especially in VW group engines have this.. lets say warm start, mid cold start and cold start.. when you crank to engine like in summer time after car sleeps over night, for heating up the cats fast to its optimal level of 400-500c, if engine has force induction, it even pushes some boost into idle for faster warming with rich AFR again.. thus helps to achieve less emissions stats..
Lviv77741.50 |
09-12-2019, 03:57 PM | #4 |
Rep 269
Thank you guys for the explanations! Heres another question. Lets say I step out of car for 10 minutes to eat. I come back and start it up, its still warm and all, and when I start it up the RPM to go about 1800. Why is that?
09-12-2019, 06:58 PM | #5 |
i'm just saying
5767
Rep 2,634
goes up to 1800rpm for a second and goes back to normal.. you mean that?
09-12-2019, 10:32 PM | #6 |
Rep 269
09-13-2019, 01:08 AM | #7 | |
i'm just saying
5767
Rep 2,634
after 2nd gen start-stop systems, ECU notes each pistons position for faster start and to avoid this over dumped fuel.. as you know when releasing the brakes engines comes back to life pretty fast just on the idle rev required for faster response.. cause start-stop sequence is pretty different than cold starts or mid cold starts..
NorthCountryGuy1713.00 Lviv77741.50 |
09-17-2019, 02:30 AM | #8 | |
Rep 269
