Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs)
      07-25-2019, 09:08 AM   #1
Terrancemw
Drives: 2019 330i
Paint scratch!
I have a jet black 2019 330i. I noticed a few scratches on my paint yesterday. It looks like the clear paint but I am not 100% sure. I am not sure how it got scratched near the top of the car. The scratch is not abrasive and the car is not dented. Will touch up paint fix this or does BMW cover paint? Have any of you had similar scratches?
      07-25-2019, 03:52 PM   #2
gpdriver17
Drives: F90 M5
If you can't feel it with your fingernail then it can likely be polished out. Contact a local detailer. Touch up paint makes things look worse a lot of times. Unless someone does it right by wet sanding and polishing after applying it.
2018 BMW M5
2018 Porsche GT3
2023 Porsche Macan S
2023 Porsche 911 Turbo S
      07-28-2019, 10:35 PM   #3
TwinPowerF30
TwinPowerF30's Avatar
Drives: 2008 335i Coupe
That looks like scuff in the clear coat. You can even try polishing it by hand with abrasive polish.
      08-22-2019, 04:07 PM   #4
Calamari
Drives: 2024 G21 330d, 2008 E87 118i
If it isnt deep I would polish this out. Touch up paint for this kind of scratch can easily make things much worse than it is now.
      10-23-2019, 09:01 PM   #5
Willy88
Willy88's Avatar
Drives: 2019 G20 330i xdrive
https://g20.bimmerpost.com/forums/pi...ictureid=72080
https://g20.bimmerpost.com/forums/pi...ictureid=72079
Someone scratched my car cause he’s an idiot and can’t drive but I didn’t see it. Does anyone have advice as to what would happen if I don’t fix it. Also does anyone know of shops with a good price near Brooklyn, NY 11220. I prefer to fix it
      10-24-2019, 04:07 AM   #6
Calamari
Bumper is all plastic so it will not corrode. Nothing will happen to it if just leave it scratched as it is now... .
      10-24-2019, 06:20 AM   #7
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
Drives: BMW G20 330i RWD M Sport
That will polish out with either a machine polisher or by hand with the suitable cutting compound.
Machine polisher will be easier if you have one.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      10-24-2019, 10:33 AM   #8
Calamari
The scratch in this picture: https://g20.bimmerpost.com/forums/pi...ictureid=72080 will definitely not go out with polishing. It's clear that the cut went all the way through the color to the bumper's plastic base layer.
To minimize the visual impact this can be painted with a careful touch-up paint job (Dr. color chip, or OEM touch up kit).
Before proceeding to the actual paint job, damaged area first needs to be polished, cleaned and degreased in order to mechanically remove the residues of the damaged paint and plastic bits that are sticking above the surface of the paint.
Tags
paint correction, paint damage, scratch and dent
