| 03-27-2019, 01:16 PM | #1 |
Rep 5
Big Brake Upgrade e70 X5 35d
I own a 2012 X5 35d. Last year I upgraded the wheels to offset 20". I need new front brakes and would like to upgrade. Looking for advice on whether the following setup will work:
f85 Rotors 34112284901 & 34112284902 f15 M sport brake calipers 34117847241 & 34117847242 M8 x 12mm Hex Head bolt x2 34111123072 SS Brake kit ECS 002565ECS01AKT2 Brake wear sensors (Need PN) Dust shield (Need PN) Advice on anything else I need would be greatly appreciated, Thanks! |
| 03-27-2019, 07:29 PM | #2 |
Need mo $$s
1738
Rep 1,451
Hi,
A search will provide a number of threads with various options... ![]() Here is one option that several of us have done: https://www.xbimmers.com/forums/show....php?t=1401599 Thanks, John
2020 TRM-BLACK X4///M Competition <My Build>
1995 Dodge Stealth TwinTurbo, 2025 Mini Countryman ALL4-S Past: 2020 X3M, 2020 Macan, 2008 X5 4.8 ![]() |
| 04-01-2019, 12:50 PM | #3 |
Rep 5
Thanks John. I have read through that thread and others but I am looking at a slightly different setup. Specifically I'm wondering if the calipers from an F15 X5M will fit on my non-M e70 X5.
This thread: https://f15.bimmerpost.com/forums/sh....php?t=1053648 shows the F15 calipers fit on an e70 X5M, but doesn't mention whether they will fit on a non-M. Thanks, Nick |
| 04-01-2019, 06:41 PM | #7 | |
![]() ![]() 187
Rep 344
You're welcome. Yes - I run the F85 rotors and F15 F/R calipers on my 35d. You will only be able to use one set screw in the front so order 2 x 34111123072, these dont have a flange like the ones needed for the f15 rotors. Can't use the set screw in the back at all but it will be fine. Last edited by Deftronix; 04-01-2019 at 06:46 PM.. |
| 05-16-2019, 10:15 AM | #8 | |
Rep 2
| 05-16-2019, 10:38 AM | #9 |
![]() ![]() 187
Rep 344
If not going used market it would most likely be a better value to get the F15 M performance brake kit (34112348054) which comes with F & R and all the other things you need like dust shields, expansion springs, pads, rear caliper carriers etc for $2.7K. The front F15 rotors and calipers (without hardware, pads, or dust shields) would be $2.4K alone.
What I did was bought the kit and flipped the rotors so I could offset the cost of some F85 rotors. Ended up spending 3.5k for F & R with F85 rotors, ECS SS brake lines and 2L Castrol SRF. |
| 05-16-2019, 01:29 PM | #11 | |
![]() ![]() 187
Rep 344
Night & day difference. It stops extremely fast for a 5400lbs car. Can't tell how much of the improvement came from the brake kit compared to the SS lines since I did them at the same time. |
| 03-04-2021, 09:25 PM | #12 |
Rep 5
would i get the replacement wear sensors that come on my car or get the ones for X5M? I have a 2011 40D.
| Bookmarks |
