10-30-2018, 10:42 PM | #1 |
Rep 266
Te37 square
I'm thinking of switching up my staggered te37 set for a squared set. I was wondering if the KW clubsport 2-way fit 18x10.5 +21 with 275/35. I want to stay away from using spacers also.
Please post pics if similar setup. Thanks! |
11-01-2018, 03:45 PM | #2 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
You will need a 10mm spacer in the front unless you swap to a shorter spring to gain inner clearance. Even then you might need a small spacer.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
12-21-2018, 06:06 PM | #3 |
Rep 4
Yeah, you'll most likely need a spacer. I just mounted 18x10 +20 (after a spacer) with 275/35/18 Federal RS-RRs and it was rubbing by coilover. I had to run a 10mm spacer. RSRRs are known to be a bit wider. KWs are also known to get in the way a bit as well.
12-21-2018, 07:37 PM | #4 |
Rep 266
Assuming the spring or perch was out of the way, you're saying the KW strut is larger than other coil over struts?
12-23-2018, 06:58 PM | #5 | |
Rep 6,218
