      07-18-2018, 09:36 PM   #1
-c-
-c-'s Avatar
Drives: bmw
Quad climate control issues
Well not for me anyway . On the passenger side it's somewhat warm and down below by the feet it's hot and that's with ac set to 60 degrees.
The ac system has been recharged and was only .5 lbs low anyway but problem still persists. Left side is always pretty cool unless it's like 90 out or above.
Any ideas? Flap motors perhaps?
I cycle through the options to turn the lower vents off so the hot air doesn't come out but the Luke warm air still comes out the passenger side.
Rear air is cold and driver side is good but passenger side front has issues.
      07-18-2018, 10:49 PM   #2
9vapors
Drives: CB X5M
I won't be much help, but recently someone was having a similar issue and someone mentioned that it's pretty common for the heat to get stuck on. Try changing the mode and see if changing it to face only changes anything.
Found the thread: AC Issue https://www.xbimmers.com/forums/show....php?t=1499441
At least it somewhere to start and some folks to ask.
Also, before you can recharge with one of those cans, you should drain the old first, I learned this the hard way.
      07-19-2018, 06:44 AM   #3
-c-
-c-'s Avatar
Drives: bmw
No worries dealer did a complete system recharge.
Just still blows warm in spots. Like you said probably a flapper somewhere
