02-16-2018, 11:53 PM | #1 |
Rep 125
Auto Downshifts In Manual Mode?
Just curious, do most of you pull the paddles as you decelerate or simply let the car downshift for you? I'm asking about a deceleration to a stop light/sign, not a track event.
I typically just pull the paddles to downshift at ~1250rpm, but the car shifts itself much smoother at ~1000rpm and I'm wondering if my current driving style is just unnecessary wear on the DCT? |
02-17-2018, 05:07 AM | #2 |
Rep 687
I only shift manually when driving hard and in that case i shift up and down myself
I see no point shifting manually up if going on a leisurely drive |
02-17-2018, 02:15 PM | #4 |
Rep 5,236
Same here ... almost always in manual w/ downshifting and zero issues.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
BMWM5NYC502.00 |
02-22-2018, 02:36 PM | #5 |
Rep 11,891
I posted about something similar here: http://f10.m5post.com/forums/showthread.php?t=1464594
my issue is that I think that you may be lugging the engine at speeds 2k and below in gears 3-7. I would not feel comfortable downshifting at 1000 or even 1500. I've decided the best DCT program to use in all applications is D3 which is akin to if you're doing it manually, keeping the engine speeds above 2k at all times, even in gear 2 if possible.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
02-22-2018, 09:07 PM | #6 |
Rep 385
I think downshifting to utilize engine braking for normal stopping is just a matter of situation and personal preference at that moment. The DCT logic will prevent you from downshifting if the resulting RPM will be above redline, so even the danger of a missed downshift on a manual gearbox is not even there.
Lugging is when you try to accelerate in too high a gear at too low RPMs, and the ability of the engine to speed up is actually limited by the gearing. There's no lugging when you are slowing down since the fuel is essentially shut off. https://jalopnik.com/actually-engine...ine-1818491096 I drive in manual 3 all the time. I tried the auto modes but use them rarely. No issues with downshifting or engine braking. |
bquicksilver25.50 |
02-23-2018, 05:24 PM | #7 | |
Rep 11,891
That's why in auto, I keep it at the 3rd setting, bc it most situations, it downshifts at 2000 rpms
02-25-2018, 02:24 PM | #8 |
Rep 125
This conversation is more related to deceleration in daily traffic and just minimizing wear (if only mild) at such times. Lugging isn't an issue there as TLK noted. Sure, if I'm cruising around and accelerating from 1100rpm I'd agree that's "lugging" it. I don't have much data on how easily the M5 knocks in that second scenario so I won't comment there.
In all honesty I was just feeling out the group to see if others drove that way to work around engine braking when there's no fun to be had at 13mph as you approach a light. |
