05-31-2008, 07:18 PM | #1 |
Rep 1,973
Cleaning M steering wheel.
Should we just clean our M steering wheels the same way we would the seats? Cleaner then conditioner of our choice?
MDCT ... so you can drive and eat a hamburger at the same time. |
05-31-2008, 08:15 PM | #2 |
Replicant
Rep 199
I had always thought it was a no-no to use conditioner on the steering wheel, at least the parts you grip. Doing so has the risk of making it quite slippery I would guess. Love to hear different.
05-31-2008, 08:18 PM | #3 |
Rep 1,973
This is what I thought too so that's why I posted. BUT, I just used some Z9 and Z10 on the arm rest and it didn't end up greasy or slippery. The leather just soaks up the conditioner. M leather isn't slippery, but it's buttery soft.
06-02-2008, 02:57 PM | #5 |
Perfection Is In The Details
67
Rep 1,044
You have to condition it with a true leather conditioner. Some conditioners are just like dressing and will leave it super slick.
I use CG Leather Conditioner and it works great. Just put a small amount on a foam pad, put the pad in the palm of your hand, grip the steering wheel as normal, and work your way around. Let the conditioner soak in for a bit, then come back with a good MF towel and to the same thing (place in palm, grip steering wheel as normal, yadda, yadda yadda). You just want to get the excess off. It makes the wheel feel smooth, clean, and is not slick at all.
2006 E90 SG-Dinan Ram Air Intake-Dinan Throttle Body-Dinan Exhaust-19' Hyperblack CSL's-15/5 tint-Matte Black Grills-M3 Spoiler Lip-Amber Delete-Smoke Side Signals |
06-02-2008, 03:33 PM | #6 | |
Rep 1,973
06-02-2008, 05:13 PM | #7 |
Rep 1,274
The Z9/10 will work great on the steering wheel. Is important actually to clean it on a regular basis as the steering wheel get "exposed" to a lot of dirt, and after a while it may be hard to take it off. Its also an area subjected to a lot of wear (no shit! )
06-03-2008, 03:43 AM | #8 | |
67
Rep 1,044
On the other hand CG's leather conditioner does not smell so great in the bottle, but in my option it is much better than Zaino. You see, CG leather conditioner is designed to bring out the new, natural smell of your leather and not create a smell of its own. So in conclusion use Zaino if you like the smell of the bottle and want you car to smell like that, or use CG if you want to achieve the new car smell. You just need to give CG leather conditioner a day or two to mix with the chemistry of your leather, so give it some time before you bash it. My car has 38,xxx and it still smells like new! If you are looking for something above both, then go with Leather Master Trio. It is great stuff and the best stuff for leather, but it is expensive. You can find it on detailersdomain.com, so go check it out. Everyone take care and enjoy good smelling leather in good health! Jared
06-23-2008, 12:07 PM | #9 | |
Rep 46,029
06-25-2008, 03:12 AM | #10 | |
///M3 Enthusiast
397
Rep 993
Drives: 05' M3 and 21' Tesla Model 3
As for steering wheel do not use a Mr. clean sponge!!! It destroys the leather!!! And a good thing to use would be just water first! water should work all the time with a tooth brush. If it is heavily soiled with dirt then mix it with a tiny bit of auto wash soap and then add some conditioner on afterwards. Best regards, Takumi |
06-25-2008, 10:20 AM | #12 |
Rep 1,161
I've not owned a ///M before. Does the tri-color stitching on the steering wheel get dirty with time and if so, how do you clean it to keep the colors vibrant?
06-25-2008, 10:45 AM | #13 |
Rep 436
I use Meguiar's spray bottle leather cleaner/conditioner on all the cars I've had in the past. It works great-- leaves the leather looking clean, reduces/prevents wrinkling/cracks, and without an overly glossy shine.
2008 Sparkling Graphite e90 M3 6spd
06-25-2008, 11:47 AM | #15 |
Rep 1,973
I was wondering the same thing. So the first time I cleaned/conditioned the wheel I went around the stitching ... screw that. The second time I just did the whole thing and it looks fine. Just make sure your coats are even and complete.
06-27-2008, 01:11 AM | #16 | |
///M
160
Rep 1,867
07-22-2008, 09:44 PM | #18 |
Rep 1,926
Bumpsy...
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
