      11-06-2017, 07:48 AM   #1
Lumpimeister
Drives: BMW X5 e70
BMW X5 E70 Handbrake issue
Hi there, i have a 2011 BMW X5 E70.
i had an alert while parking that the parking brake had failed. i checked the fuse and a reset evolution that i found on Youtube but this did not work.
When i press the Automatic handbrake button the car alerts me that this is also faulty and the light does not come on.
When driving along if i lift the lever the handbrake comes on, which would lead me to think the actuator is ok.
has anyone had the same thing happen and if so what did you do to resolve it.
i am hoping it is a faulty switch, rather than the actuator.
regards
Lumpi
      07-04-2018, 06:26 AM   #2
X5Piper
Australia
Drives: BMW X5 2008
I have exactly the same issue with my handbrake as you. Actuator works if I pull it up whilst driving...otherwise it is shows a fault. I need to know if you had a fix for it since posting thanks?
      07-04-2018, 08:42 PM   #3
RichardR0404
Drives: 2013 BMW X5 35D
I pulled the battery terminal off for couple hours before, my car was stuck with park brake on.. errors gone
      10-12-2018, 12:43 PM   #4
chris604
Drives: X5 M
Hey all. just had the same issue 2010 X5M. parking brake went on fine when I parked it. a few minutes later I pressed the unlock button on the keyfob. Made an insanely loud screaching noise, which I thought was a door attempting to unlock or something? Maybe unrelated to the parking brake issue? very bizarre. Then tried to drive the truck, but parking brake fault lights and message came on, so was stuck. Tried pulling fuses, and stepping on brake with parking brake switch up or down for 5 seconds. no luck. Just used the orange handbrake release tool which was in the trunk to pull up the handbrake, and was able to drive again. Any idea how to fix it easily?
Thanks!
      10-12-2018, 05:40 PM   #5
chris604
Drives: X5 M
You think pulling the battery cable would reset it?
      11-21-2018, 06:23 PM   #6
zoofari
Drives: 11 x550i
P light on, car drivable and park brake not engaged. a shop used an after market 300$ park actuator doesnt do anything, tried 2 of them. maybe order the 1100-1300$ OEM to try luck. Any of u resolved the issue and how?? please save me here.
      11-21-2018, 10:35 PM   #7
N62B48
N62B48's Avatar
24
Drives: XDrive 4.8i
I had same problem few months ago, replace the brake actuator.. the new bimmer system use plastic teeth actuator when those plastic teeth chewed or stripped your emergency or hand brakes wont pull, work anymore.It will give you faulty message.
Remember our X5 comes with AWD system you dont need to use the hand, emergency brake it will not roll by itself, unless its FWD or Rear wheel Drive..
      11-21-2018, 10:37 PM   #8
N62B48
N62B48's Avatar
24
Drives: XDrive 4.8i
I purchased the actuator from EBAY $250 buks, Kustler parts.
      11-29-2018, 12:42 AM   #9
Charlieborg
Drives: 2009 BMW X5
2009 BMW X5  [0.00]
Did this work?
Did you get the brake to working again?
      11-30-2018, 01:21 PM   #10
chris604
Drives: X5 M
I couldn't get mine to work again. Dealer wants $3500 to replace. Plus programming of $250. LOL.
      11-30-2018, 07:21 PM   #11
TKR
Drives: 2016 X5 40e & 2018 330e
BMW has obviously set planned "end of life" self destruction to the hand brake system to November 2018 because I've seen many posts on this issue lately, and suddenly my handbrake started acting as well.
Well, just cleared the fault codes and then it started working again. Mystery.
      12-03-2018, 06:19 PM   #12
chris604
Drives: X5 M
Definitely. My actuator was shot, so resetting fuses, pulling battery cables didn't work. Getting it done now as we speak. they also said it requires programming? How do you program a brake actuator? It's just an automatic parking brake, vs. you having to pull it by hand. LOL.
      12-04-2018, 10:18 AM   #13
Ghanziang
Ghanziang's Avatar
Drives: 2012 BMW X5 3.5i Silver
2012 BMW X5  [0.00]
Curious what the programming required is.
G
      12-05-2018, 01:22 PM   #14
chris604
Drives: X5 M
G
Yep, got charged for programming. It was probably because once the battery is pulled, then everything is reset, so has to be 'programmed' at the dealer. Or, could have been an unneccesary charge. Not sure exactly. But, all my settings on xdrive were all reset. Runs great now though, parking brake working fine. very quiet now, b4 it was noisy.
      12-05-2018, 01:57 PM   #15
Ghanziang
Ghanziang's Avatar
2012 BMW X5  [0.00]
Thanks for the update!
G.
      11-30-2019, 08:42 AM   #16
nuwde
Drives: 2010 X5 M
Did you replace the actuator yourself? Has it given you any problems since? Did you have to program it anything?
      11-30-2019, 08:48 AM   #17
nuwde
Drives: 2010 X5 M
Can you update us on your hand brake status after clearing the fault codes? Thanks!
      12-29-2024, 03:15 PM   #18
IMcIntosh
Drives: X5 Z3 118i
Accidental but effective reset
I had the same issues as you all, message on screen, dining warning, red and orange brake light continuously on the dash. I tried all the fixes mentioned here and on youtube with no success. Then purely by chance and frustration I had the car in drive crawling very slowly and I simply turned the engine off which stpped the car suddenly and automatically engaged the parking brake. When I turned it back on NO WARNINGS, NO DINGING. NO ISSUES. Everything had reset itself and is working perfectly!!!!! That was 2 weeks ago and it is still working as it should. I can't go back and do it again but maybe someone would like to try and confirm or deny? Good luck as I know how frustrating this issue is.
      12-29-2024, 06:10 PM   #19
jbash87
Drives: 2006 M5, 2012 X5d, Prelude 4WS
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Nope... Don't do what the guy above me says.
If you're having issues, no corrosion on your connector, and none of the reset procedures seem to be working, then you most likely have an issue with the electric motor leads within the parking break actuator. They get brittle, can work intermittently, then fail all together. Happened to mine multiple times. I was successful in re-soldering them a few times but finally got tired of that.
The motor can be replaced with this one from ebay.
https://www.ebay.com/itm/184215716556
Very simple repair.
