06-09-2017, 01:42 AM | #1 |
Rep 8
Brembo bbk pads
Hello ,
I have brembo bbk rear 345x28 mm 4 pot caliper i'm trying to find track pads for this bbk's caliper but i couldn't find the caliper code or which pads are fits to this caliper ? Another question is this kit has 345mm rotor but can i able to buy and mount 355mm rotor and fit it to this caliper ? Thanks !! |
06-09-2017, 09:15 PM | #2 |
Rep 2,342
Probably need a different caliper bracket to run the 355 or use a 10mm spacer on the studs with 10 mm longer studs. Post a pic of the Caliper.
It's most likely the Monobloc 4 piston. Which is pad shape FMSI D810. Last edited by MasterP; 06-09-2017 at 09:20 PM.. |
06-10-2017, 01:10 AM | #3 | |
Rep 8
Thanks for your reply . Actually i've just bought the bbk from ecs tuning it was on clearance at 1280$ it didn't came to me yet but i would not like to use brembo pads on track thats why i'm looking for to buy track pads https://www.ecstuning.com/b-brembo-p...2p1.8033a~brm/ I think this is like you said monoblock 4 pot caliper so then i can search FMSI D810 pads ? |
