02-17-2016, 03:33 AM | #1 |
Rep 184
Upgraded X5M Billet Turbo Compressor Wheel $120 including shipping
So I stumbled on a eBay listing for new and "upgraded" compressor wheels for our S63, E70, X5M's. The company's name is Mamba and they are out of Taiwan. In their eBay auction they also offer additional customization of the compressor wheel (to what extent I don't know).
If you want to look for yourself its eBay item number:191790789186 Here are the most noteworthy stats for the compressor wheel. "MAMBA" Garrett GT15~GT25 MGT2260SDL 790463 / 790484 P/N:010-2590 Turbo Billet Compressor Wheel 44.5 / 60.40 mm with Performance Extended Tip (BMW X5M S63 E70) Replace wheel number : 782487-01B Fit Turbo #: 790463-2, 790463-3, 790463-8, 790484-2, 790484-3, 790484-8 Maximum boost 5 bar / 70 Psi Balanced By SCHENCK Germany Wheel Size: Nose OD : 12.00 mm Inducer Dia.: 44.50 mm Exducer Dia. : 60.40 mm Extend Tappered Tip Exducer dia : 65.43 mm Tip Height: 4.57 mm Super Back Height: 3.71 mm Overall Height : 32.40 mm Bore: 5.08 mm / Through without thread Blade : 9+0 Trailing Angle : 45 degree Rotation: Reverse Material: Forged Aluminum Supplier: MambaTek One Year Warranty So hopefully some of you guys can field these questions and shed some light on this for me. 1. Anyone have stats for the OEM E70 X5M's compressor wheels? 2. Will we see any noticeable gains from an addition like this? I know that our fuel sys. restricts us but assuming we have DP, exhaust, tune and race filters? 3. Is this a straight swap or would we need additional parts like a new housing? 4. Ever heard of this Mamba company or are they just another eBay special? 5. What else would be needed to make these compressor wheels a smart $/HP decision? 6. Would an upgraded compressor wheel like this raise the need for an updated tune or would there be a minimal degree of change? |
02-17-2016, 05:52 AM | #2 |
Rep 994
Mamba makes turbo parts usually for the import japanese market like subaru, mitsu, and Nissan. An alternative to the real deal garrett parts at a fraction of the cost.
They are complete blatant copies in most cases. Not a bad thing for a consumer if it works.... Folks on those respective forums have bought those turbos and made more power than stock. But have also suffered quality control issues too, with little support from the selling vendor. If you csnnot get the appropriate tune do not bother do not pass go is my opinion |
02-17-2016, 07:38 AM | #3 | |
Rep 184
02-17-2016, 03:46 PM | #4 |
Rep 286
Our stock compressor dia is 60mm, it looks like these are extended 5mm. So machining is probably required to make the compressor housing fit.
There is another billet wheel listed that looks like it's the same wheel through a different seller. The extend tip diameter number look swapped around but otherwise the same. http://www.ebay.com/itm/Billet-Turbo...FV47k4&vxp=mtr I'm running PURE TURBO stage 1 upgrades and didn't have any issues running on the stock tune. Working with BPM motor sports to get a tune for the upgraded turbos. The limit on our engines is the the MAP sensor only reads to 22-23psi. Most tunes run 20 psi on the stock turbo because it runs out of breath on the topend. Looks like that will be the first limit we'll run into with upgraded turbos. Which will be a problem because nobody wants to support rescaling the pressure map for the 4 bar map sensor newer BMWs use. I asked. Fuel will probably be next after that. Last edited by Myaddiction; 02-17-2016 at 03:59 PM.. |
02-17-2016, 06:20 PM | #5 |
Rep 994
The MAP is not an issue really. You can tune around it with a larger MAF and MAF scaling. Of course, again, tuning and finding a tuner capable on this platform I have yet to see. These are common issues on Subaru's, and other turbo charged imports. There is a whole aftermarket using GM MAP sensors, AEM sensors, etc...
02-18-2016, 07:31 AM | #6 |
Self Proclaimed Roundel Junkie
714
Rep 1,674
My thoughts, no way am I buying turbos or turbo internals from eBay... I'm intrigued that some of you are doing turbo swaps, but for me, the X5 is just the wife's vehicle... A tune and things, I'm all for... but I'm not going much deeper than that...
2013 E82 1M3 - Carbon Black/Black S65/DCT Track Toy
2018 F15 X5d - Carbon Black/Nutmeg Individual Oil Burner Tow Rig 2021 G07 X7 M50i - Tanzanite Blue/Ivory White & Night Blue German American Family Rig Former Family: '13 F25 X3 35i, '11 E91 335is, '11 E90 M3, '10 E70 X5M, '14 F30 328d, '03 E46 330i Dinan3 ZHP, '04 E46 330i ZHP, '12 F25 X3 35i |
02-18-2016, 08:48 AM | #7 | |
Rep 286
The MAP sensor would be a simple fix if you can rescale. The problem is we are such a small market nobody wants to spend the time scaling our ecu for the higher reading MAP sensors. Do you have the tools or know a tuner that will do it? The ones I spoke to said no thank you as there are a total of 3 of us with upgraded turbos. |
02-18-2016, 08:49 AM | #8 |
Rep 261
I think the biggest problem is going to be the fueling system. I think around 700hp seems to be the limit of the stock system. Since this engine is direct injection, fitting larger injectors could prove difficult.
02-18-2016, 08:56 AM | #9 | |
Rep 286
The only problem with fueling is if you don't want to run meth. That's true on any BMW turbo motor. The N54 has aftermarket port injection setups but that's not coming to our motor any time soon if ever. If you don't run meth on these motors your limited to less then 600 rwhp. That's the choices you have. |
02-20-2016, 04:31 PM | #10 | |
Rep 472
02-22-2016, 03:35 PM | #11 | |
Rep 318
02-23-2016, 11:14 AM | #12 | ||
Rep 286
You simply won't make good power on 91 California gas. The blend is not knock resist at all and acts like 89 found else where in the country. It's focused on smog reduction first. You can't break 500rwhp on it in these motors let alone reach the systems fuel volume limits which are much higher if you have the octane to support the boost. I add E85 to my tank making a E30 blend and you can see the difference right away as timing climbs up without the knock 91 produces even on a stock tune. |
02-23-2016, 12:08 PM | #13 |
Tanzanite Blue II X5M Pilot
1098
Rep 2,077
Drives: M3, M4, X3 M40i, X5M
My Indy Master Tech told me to stay away from E85!
02-23-2016, 01:55 PM | #14 | |
Rep 286
We can't run straight E85 only because our software can't support it and nobody is going to invest the time in changing that. Hardware wise there is nothing preventing the use of E85. There's a lot of myths and lack of knowledge about it. This is my 3rd BMW I've used it in (335i and M4) and 5th vehicle. You just need to know what you're doing. It's worth a lot of power but isn't just pump and go. If it's readily available put 5 gallons in the next time you fill up and you can tell the difference due the more advanced timing unless you're running 93. The difference isn't that large then but there are still gains. I'm still data logging and working with the tune to find out how much E85 I can run and how much power it's worth, but know that E30 is a safe mix that makes power in our trucks. |
02-23-2016, 08:47 PM | #15 |
1098
Rep 2,077
I only run Shell 93 in my vehicles.
The lack of knowledge is exactly what scares me; A guy who regularly visits my buddy's shop swears by e85, yet he continues to have a check engine light issue every time he uses it.... go figure! |
02-24-2016, 01:28 AM | #16 | |
Rep 286
I've seen it numerous times on the stock tune when I add to much E85 in the mix. No impact to the motor. |
02-24-2016, 08:06 AM | #17 | |
Rep 184
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners |
02-24-2016, 08:59 AM | #18 | |
1098
Rep 2,077
02-24-2016, 10:19 AM | #19 | |
Rep 286
The ECU always operates in closed loop so it will always hit its targets if it is physically capable. |
02-24-2016, 10:25 AM | #20 | |
Rep 286
As long as your vehicle was made after the 2006 clean air act was passed mandating ethanol use in gas, its fuel system has the right materials to handle it if that's what you're worried about. |
06-07-2016, 10:03 PM | #21 | |
Rep 2,062
After seeing this thread - http://f10.m5post.com/forums/showthread.php?t=1267910, I was talking with lfelunden and he said it's not needed on our platform because he claims he can boost beyond the limit of the stock sensors (which I'm guessing is ours since he mentioned it) on the MEVD ECU only.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
06-07-2016, 10:09 PM | #22 |
Rep 2,062
M5 uses different injectors than we do, so that might be an irrevelant point...I've still got my fingers crossed that we'll get to their level though as I spend more time on the M5 boards than here since they're pushing the limits.
