Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      07-18-2015, 11:34 AM   #1
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
Broke my M4 this am!
While bedding in brakes & heat cycling tires 1st session my transmission decided to stop delivering power in the odd numbered gears and there is a loud thumping noise while it is trying to deliver power in those gears.The strange thing is there are no notifications alerting to a problem.I was only puttering waiting for the temps to come up.I drove the car to the dealer which was about 80kms away using the even numbered gears.Everything points to the No1 clutch going
      07-18-2015, 11:38 AM   #2
gthal
gthal's Avatar
Drives: 2018 340i xDrive
That is really unfortunate. The DCT has proven to be pretty tough so I'm interested in the outcome. Hope it is fixed soon!
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      07-18-2015, 12:21 PM   #3
Gearhead999s
817
I missed two days this weekend which were going to be setup days and co driver familiarization for the Ontario 1500 which we are running in September.I think the key thing is having two cars that can be tracked.My dealer was suggesting an M2 for my wife to solve this
Issue!
      07-18-2015, 03:54 PM   #4
CanAutM3
CanAutM3's Avatar
Drives: 2021 911 turbo
Ouch
I wonder if there is any relationship with your brake issues .
Keep us posted.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      07-18-2015, 04:44 PM   #5
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
Geez you keep breaking your car. You must be doing it right!
      07-18-2015, 04:46 PM   #6
Gearhead999s
817
Originally Posted by CanAutM3 View Post
Ouch
Keep us posted.
I do think it is a mechanical issue as there no warnings or anything in the memory.At least my service advisor has a M Coupe has been to the track with myself at one of the dealership track days.
      07-20-2015, 12:41 PM   #7
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
With all the electronics on the car you would think a warning would pop up due to some code being thrown.
Mike
      07-20-2015, 01:04 PM   #8
Gearhead999s
817
Mike
We are thinking it is a mechanical issue which is why it did not throw any codes.If it was a control unit issue it would have popped a code!
      07-20-2015, 01:07 PM   #9
morgan302
Drives: m3 2015
2015 M3  [0.00]
2015 BMW M3  [0.00]
So may be the loud thumping noise is a new way by BMW to let you know something went boom. You know the Germans only do things the correct way.
      07-20-2015, 03:02 PM   #10
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
I'm certain BMW will address the issue for you under warranty. I'm interested to see what the problem was! As mentioned above, the DCT transmissions are stout- my hope is that this failure was an outlier.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      07-20-2015, 03:24 PM   #11
Gearhead999s
817
The dealer e mailed me that they are doing a program update 1st as per BMW and they will see what happens once this is done.They feel it is a mechanical issue also.
      07-20-2015, 03:29 PM   #12
IND-Distribution
9587
Interesting! From what I've seen, BMW's warranty process (as it relates to transmissions) skips through a few simpler steps like the one you just mentioned, and typically lands at "let's replace the whole transmission". I'm hoping for the best result for you.
      07-20-2015, 03:32 PM   #13
Woodengun
Drives: Yugo
Must be one of the clutches. One clutch is for even gears and other for odd. One of the reasons why the DCT is so quick.
      07-20-2015, 03:41 PM   #14
Gearhead999s
817
I think it had to be the #1 clutch that is the issue!
      07-21-2015, 05:59 AM   #15
chillindrdude
chillindrdude's Avatar
1161
Drives: anything with 4 wheels
broke mine too..
Rear Differential Lock Error...
either the GHAS unit is toast or the entire diff. i feel like it's an overheat issue.
My Trackable Street Car
2016 BMW M4 GTS
      07-21-2015, 12:08 PM   #16
Gearhead999s
817
They did the programming update and no change in the problem as we expected. Waiting for BMW to make the call of what to do next!It is a Puma case according to the dealer.
      07-22-2015, 10:45 AM   #17
IND-Distribution
9587
As you stated, it must be a hardware issue at this point!
I'm hoping for a swift resolution for you.
      07-22-2015, 12:56 PM   #18
Gearhead999s
817
Here is todays latest communication.
Heard back from BMW again and they want us to perform a shift rod travel test procedure, after which they can determine if there is an issue with the mechatronics as well, and finally if we have the results they are looking for they can authorize for us to take the transmission apart and check for debris.
I know this may seem like a lot of steps but mainly because it is such a new vehicle we need direct authorization from BMW to perform any kind of repair.
The worst thing is I am really quite carefull not doing anything dumb with my driveline.No launch control starts,always full warmed up before using over 3000 rpm and using manual in traffic so it does not slip the clutch starting in 2nd.
      07-22-2015, 01:32 PM   #19
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
As in, oil temp 220F before using 3000rpm ?
that IS being pretty conservative
      07-22-2015, 01:40 PM   #20
Gearhead999s
817
In my past life I played with round engines in the Canadian Far North as my job so being nice to cold engines is habit!105C is the number here
      07-22-2015, 11:51 PM   #21
ex12psi
Drives: bmw
mine had a similar behavior but i got the 'driveline malfunction' error and the DCT was skipping the even or odd (cant remember) gears. i turned the car off, the error code went away, and everything is fine.
but every now and then, randomly, i'll get that driveline malfunction error on the screen and the car will either do the gear skipping, or not shift at all, like stay in 1st gear and i cant shift out. but every single time, i can shut the car down and immediately turn back on (reboot) the codes go away and the thing drives perfectly fine.
i've tracked it pretty hard on 2 occasions and it held up to the punishment well. first time tracking the car threw that error, 2nd time tracking no errors.
      07-23-2015, 03:04 PM   #22
Gearhead999s
817
So the good news!BMW has authorized the replacement of the transmission but it will be 2 weeks before it will arrive from Germany.I have asked them if it can be airfreighted. I am pretty sick of driving the 320 XI everyday My dealer has been great through all this!
f80post
