Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      07-05-2015, 11:43 AM   #1
Demxsr
Demxsr's Avatar
149
Drives: 16 M4
BMW Ultimate Service question.
I am wondering, during this 4 yr / 50k miles period has anyone needed service on their car that wasn't covered by the service plan or warranty? Every time you bring your car in during this period is it truly no out of pocket? And are there minor things they hit you with, like disposal fees and such?
Basically has anyone had any bad experiences with it?
Here is a list of what BMW says is covered if you didn't know.
Engine Oil Services: $0
Inspection Services: $0
Wiper Blade Inserts: $0
Brake Pads: $0
Brake Discs: $0
Engine Drive Belts: $0
Brake Fluid Service: $0
      07-05-2015, 11:51 AM   #2
alex2364
alex2364's Avatar
2901
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
It's 50k miles, not 100k miles. The only thing I've had to pay for are tires and alignments.
      07-05-2015, 11:56 AM   #3
PodDoc
Drives: 2013 F30 335i / 2016 F80 M3
Im pretty sure its 4yrs/50,000 not 100,000 miles. Which ever comes first. But to answer your question. I havent had any problems what so ever. There are never any special fees that they tack on. Ive had a couple oxygen sensors fail and a problem with the fan, always covered under warranty without hassle. I have never paid for a thing.
So far my experience with the dealers have been so good, it has been a major factor when i cross shop for other cars. Looking at the price of an M3 vs C63. BMW's maintenance plan is worth a couple thousand dollars in consideration. With other makes it has sometimes been a hassle to get things covered under warranty but with bmw never an issue. I never have to worry about extra costs besides for tires during the 4years which is huge for me.
      07-05-2015, 12:36 PM   #4
Demxsr
Demxsr's Avatar
149
Drives: 16 M4
Oops, edited. I knew that! Not sure why I put 100k. Probably because that's what I get with my Sonata. Wishful thinking I guess, haha.
      07-05-2015, 12:40 PM   #5
Demxsr
Demxsr's Avatar
149
Drives: 16 M4
Ya this was a big thing for me too. After doing some research, some parts of Benz's are purposely engineered badly to cost more to maintain. And the general maintenance costs with them is just outrageous.
      07-05-2015, 12:53 PM   #6
2000cs
Drives: Potato
I've driven in for wiper inserts and washer fluid, done quickly and no charge. Never a problem or cost with this service.
      07-05-2015, 01:08 PM   #7
04RC51
Large Member
04RC51's Avatar
951
Drives: E92 M3, F82 M4
I've never paid a dime on my E92 or F82.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
      07-05-2015, 01:51 PM   #8
elias
elias's Avatar
81
Drives: M4
The Dealer always tries to tell me that my car needs an alignment I always say
you can do an alignment when my Lease is up! I would know if I needed an
alignment give me a break!
      07-05-2015, 01:54 PM   #9
spectrumphoto
Just another peanut in the Turd!
spectrumphoto's Avatar
Drives: g16M850;f30M550;f80M3-ED;e90M3
Be prepared to have to pay for oil, though doubt the f8x series will be as big of oil hogs as the e9x Ms, but out in California oil changes were covered under maintainence but topping off the oil was not covered and at $15 a quart it was a small nuisance
      07-05-2015, 02:19 PM   #10
MRCUR
MRCUR's Avatar
Drives: 2018 Model 3 Performance
The only thing I have ever paid for is replacement tires and associated labor. I haven't even paid for alignments so far.
State inspection isn't covered either of course, but my dealer is almost always running specials on those.
      07-05-2015, 02:37 PM   #11
PodDoc
I know each dealer is a bit different but at my dealer, they have quarts of oil in the drop off bay along with washer fluid for quick top offs. I just tell them i need some oil and they top it off, no questions, no charge. If its been a while since my last top off/oil change and im going on a longer road trip, i stop by and they have just given me 2 quarts to take with, no charge.
      07-05-2015, 03:08 PM   #12
Alpine300zhp
Drives: 24 M4 Comp/24 X3 M40
Yeah. Mine also recommends an alignment every time I get tires. I always decline. I drive 30k miles a year and I know when it needs an alignment.
~ 24 M4 Comp
~ 24 X3 M40
~ Prior BMW's - Too many to list here (27)
      07-05-2015, 03:16 PM   #13
direwolfM3
Drives: 2015 F80 M3
May depend on the dealer but this seems like something that should fall under regular maintenance. I would stop in multiple times a year for a quart of oil at no charge. Sometimes even giving me a quart to take home in case I need it at a later time.
      07-06-2015, 02:11 AM   #14
spectrumphoto
Trust me...it became a battle with my dealership...then I went to 3 other local dealerships and had the same issues there, no tops offs of oil for my e90M, but they were more than happy to add a quart for me just as soon as I purchased it from Parts Dept.
This went on for all 4 years of my covered maintainence.
      07-06-2015, 12:05 PM   #15
Demxsr
Demxsr's Avatar
149
Drives: 16 M4
I doubt the F8X is as much as an oil hog. Hopefully I should be fine topping it off at the regular service intervals?
      07-18-2015, 10:00 AM   #16
mafiesso
mafiesso's Avatar
17
Drives: 2015 M4 Vert SB/SO
Not true. I've been getting oil top offs once a month for the last 4 years on my E93. The dealer will gladly top you off with a quart of oil, no charge.
2013 E93 M3 - Silverstone II/Individual Amarone Red Extended
2011 E93 M3 - Lemans Blue Metallic/Individual Rust Brown Extended:
http://www.m3post.com/forums/showthread.php?t=508879
      07-24-2015, 09:13 PM   #17
spectrumphoto
That may be the case in FL...but not in SoCal. I've been to several dealerships (including where I purchased my e90m from) and always the same issue. I've spoken to the GSM's about it even and once went soo far as to talk to BMWNA who basically said its up to dealership policys, not Corp.
f80post
