03-16-2015, 11:53 PM | #1 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
E46 M3: 18" Square Setup - will it work on F82?
Hey all,
I've been using four E46 rears for track duty on my E46 M3 for the past 10 years. Now I'm updating with the F82 and am wondering if I need to purchase new track wheels. Does anyone know if they will work for both front and rear? For reference, their specs are: Size: 18" x 9" Bolt Pattern = 5x120mm Offset = ET26 Current tire size: R888 265/35-18 I want to make sure that whatever tire/wheel combination I use will properly fit and will not rub. Thanks! |
03-20-2015, 12:01 PM | #2 |
Rep 20,741
Drives: 2021 911 turbo
You'll have to try them on. The brakes on the F8X are quite big. The Enkei NT03 18x10ET25 wheels I used on my E92 did not fit over the front calipers.
Further, 9" wheels are probably too narrow for the F8X...
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-24-2015, 08:09 AM | #3 |
Rep 984
Agreed, 9" is not enough. Even 9.5's would be tight. Look to move to an 18x10 set with 275's or 285's.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
03-24-2015, 09:05 AM | #4 |
Enjoying driving
388
Rep 1,169
I cannot comment on the sizing, but do consider that using wheels on track for that many years, regardless of how many hours you actually put on them, will pose some level of increased risk in terms of metal fatigue. This may the opportunity to get some new wheels in proper size
03-24-2015, 11:24 AM | #5 |
Rep 3,834
Try using the 513m OEM 18x10 rear wheels as square setup. You can run 275 or 285 square tires, just need 20mm spacers in front. These are about $660ea on getBMWParts and they're forged. Light and super strong for the track.
This is the setup I'm thinking of using for the track/street. I will save the 2 fronts 18x9 for my winter setup. 9" is too narrow buddy. Most M3/M4 guys run 10 or 10.5 square for track. Another option is Apex, you can't go wrong with Apex. |
03-30-2015, 08:25 PM | #7 |
Sakhir Smurf
314
Rep 594
Seems like I'll be getting a new set of wheels
Thanks for the advice, everyone!
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
