      12-15-2014, 02:10 PM   #1
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
DIY: Adjust your headlights (Xenon only)
My driver side used to illuminate very little area ahead compared to the passengers, it was easy as hell to adjust them - Only need a plus screw driver (Hex is better but I dont know what size)
1- open the hood - obviously & park abt 30 ft away w both headlights on
2- towards the driver side, look down behind the headlight (far behind the headlight), you'll see a hex female nut facing the engine ... I turned it 90 degs CCW (to lift up) - I'll post a pic
3- Samething on the passenger side, I made it 45 degs CCW s
4- Drive and confirm this is the desired setting, I had to readjust coz xenons lose brightness as u point them further out, had to find the right balance
Enjoy!
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      12-15-2014, 03:39 PM   #2
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
Nice job. Thanks for sharing.
      12-18-2014, 07:04 PM   #3
Marco Sousa
Marco Sousa's Avatar
Drives: 2012 BMW X5 xdrive 35i Premium
I think my left headlight is a bit too high on my 2012 because I get flashed high beams a lot as if I had mine on but I dont
Can I adjust it down or that's self adjusting ?
      12-19-2014, 05:44 AM   #4
SchaumerMol
SchaumerMol's Avatar
Drives: 2020 X7 M50
Here is the proper procedure for the headlight adjustment attached.
Please don't just screw around and adjust the level... make sure, based on the attached pdfs, that you actually should adjust.
There is an actual device (at least in Germany at the TUV), which verifies the proper levels and cutoff of the headlights to avoid blinding oncoming traffic.
Maybe the servo for the height adjustment (up & down) is busted.
First understand the root cause of your problem before you start messing with the adjustment screw.
      12-19-2014, 06:38 AM   #5
Marco Sousa
Thank you very much I will give that a try and see what happens
Thank you.
      12-19-2014, 12:17 PM   #6
007_e350
007_e350's Avatar
It doesn't list the screw I adjusted, and my beam did rise up
