      05-01-2014, 03:09 PM   #1
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
Next upgrade
I know it's somewhat personal preference, but I'm trying to decide on the next mod for my 50i.
I'm going back and forth between cat-back exhaust or KW V3s.
Mods I've done so far are...
- LED interior lights.
- New metallic pedals
- BAVSound 14 speaker replacement
- Hardwire passport max with blendmount
- Weathertech mats
- Coding quite a few options
- fog bulb change
- Velos tune
I'm thinking the KWs would effect my overall driving enjoyment more.
Thoughts?
Thanks!
Joe
      05-01-2014, 03:16 PM   #2
mitch808
Drives: 2012 X5 35i
Yes, a suspension overall would make the most dramatic difference. It all depends on what you want to do with the vehicle, goals, budget, etc...
Perhaps you can get by with lowering springs alone? But if an adjustable suspension is what you want, then KW is pretty much what you need to get.
      05-01-2014, 08:08 PM   #3
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
Are lowering springs for cosmetic reasons only? Any handling tradeoffs?
      05-02-2014, 01:27 AM   #4
mitch808
Drives: 2012 X5 35i
Lowering springs are typically a tad stiffer and shorter. Giving you a lower center of gravity, and firmer ride. If not designed right, when improperly matched to the dampers, you'll have a bouncy ride.
KW allows for tuning this oscillation out both on compression and rebound, as well as fine tuning ride height. At a cost of course. But its a properly designed "turn key," solution.
      05-02-2014, 10:51 AM   #5
jafeinst
Drives: 2013 X28i
Were you happy with the Bav Sound speaker upgrade? I just ordered for my base 35D system. Thanks!
      05-02-2014, 03:12 PM   #6
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
Very happy.
Clarity is 3X better. Base response isn't any better because the under seat subs are awful, but I'm considering a JL stealthbox soon.
Joe
      05-06-2014, 06:34 AM   #7
hd2000fxdl
Drives: 2011 X5
I haven't been under the set to see, but has anyone used the stock poor excuese for a Sub and replaced the speaker for a better one with good results?
I have seen people who have put them in the rear stock panels and looks like it a great setup but I want to keep the stock look of not seing them.
Harry
Harry
      05-07-2014, 06:55 PM   #8
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
Yes you can replace them, but they are tiny and it really doesn't add much.
The JL Stealthbox that fits in the spare tire compartment is the way to go.
Joe
