      07-30-2013, 06:22 PM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
LCD Headlights retrofit
Has anyone done this end-to-end? What's all that's involved in replacing original headlights with new LCD?
1.) LCD lights
2.) 2 modules for lights
3.) bulbs
4.) Footwell -3 (FRM-3) module
5.) Coding
Am I missing anything from this list? Connectors, harnesses ?
      07-30-2013, 07:36 PM   #2
isugoo
isugoo's Avatar
Drives: 991.2 GTS
complete list:
retrofit wiring harness
led headlights (l/r)
5-way mini connector
blade terminal fuse 5a (2)
cable tie (20)
rivets (16)
high pressure jet headlight cleaning system (l/r)
footwell module
and member who did the complete retrofit:
http://www.xoutpost.com/bmw-sav-foru...ld-thread.html
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3
      09-12-2013, 11:56 AM   #3
igorbmwx6
igorbmwx6's Avatar
Here is a complete BMW X6 E71 LED Headlights retrofit DYI instructions (pdf). Have everything on hand now. Just missing one item, right-hand side (passenger side) LED headlight. Once I find a good deal on it, will get this project going. Can't wait ...
      09-12-2013, 01:47 PM   #4
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Thanks for the pdf!
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      09-17-2013, 11:02 AM   #5
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
Where the hell can we find that wiring harness?
      09-17-2013, 12:19 PM   #6
igorbmwx6
igorbmwx6's Avatar
Here is a place where I purchased mine from. They are selling complete harness cable for X6 LED headlights retrofit for $99.76 with $11.76 for delivery or $31.98 expedited FedEx service:
http://e-acca.com/index.php?page=oem...orderBy=gruppa
      09-26-2013, 11:38 AM   #7
igorbmwx6
igorbmwx6's Avatar
Can someone please post some pictures or write a clear explanation as to where exactly LED headlights wiring harness is entering and exiting cabin from engine compartment at the left side and right side of the vehicle?
      07-29-2014, 03:32 AM   #8
330i zhp
Drives: X5M and SCd Touring
I took mine down under the DME and into the cabin via a rubber plug - and similar on the left side
      08-01-2014, 08:34 PM   #9
igorbmwx6
igorbmwx6's Avatar
I finally figured it out and completed my LED headlights retrofit. Was a bit scary at first, but then I was able to figure it all out without braking anything
      08-01-2014, 08:36 PM   #10
330i zhp
sweet - lights working properly?
      08-01-2014, 08:37 PM   #11
igorbmwx6
igorbmwx6's Avatar
100% working just like factory install ...
      08-02-2014, 01:53 AM   #12
Jess///M
Drives: 2016 X6M
I totally want those for my 2012!
      02-07-2016, 04:09 PM   #13
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
Drives: Audi BMW Ferrari LR MB
is there a company that sells a complete kit?
      02-07-2016, 04:14 PM   #14
330i zhp
There is an eBay seller that does....but, $$$$
      02-07-2016, 04:39 PM   #15
iconoclast
iconoclast's Avatar
how much is four money signs in USD?
looking to do this for 2013 X5M.
      02-07-2016, 06:21 PM   #16
330i zhp
http://www.ebay.com/ulk/itm/221871350225
      02-07-2016, 06:22 PM   #17
330i zhp
It will likely cost less to assemble the parts yourself
      02-07-2016, 06:24 PM   #18
330i zhp
If I recall correctly, my conversion was about $3800 for everything.
      02-08-2016, 09:17 PM   #19
igorbmwx6
igorbmwx6's Avatar
Mine was approximately: $1100 each light + $300 FRM3 + $150 Wire Harness. The rest is history. Two days of enjoyment. Working outside in beautiful Nor-Cal weather.
      02-09-2016, 04:36 PM   #20
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
Drives: M3 COMP
Mine cost me about $3500 did everything my self but codding
Btw I have a brand new FRM3 that u might need for retrofit
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
      02-10-2016, 10:46 AM   #21
black1
black1's Avatar
Drives: Pure Metal M6GC
why did yours not need the frm3?
      02-10-2016, 11:51 AM   #22
Gatoferoz25
BeastM3r
Drives: M3 COMP
I bought and extra one thinkin that mine was bad so I ended up with 3 while doing the retrofit
