06-28-2013, 05:55 PM | #1 |
Rep 8
CCC to CIC idrive controller - Help!
Just bought a CIC idrive controller, mount and trim from a 2010 model E70 (UK) to upgrade my CCC idrive controller in my 2009 model as I was told it was just plug and play from a local BMW specialist.
Alas It lights up fine but wont control anything. Can anyone steer me in the right direction as what I need to do? I have read around on forums about getting the controller coded or something about swapping the wires around in the connector. All software has been recently updated to to the latest version for all modules as well by BMW Any help would be greatly appreciated! |
06-28-2013, 06:27 PM | #2 |
Rep 6,125
I had 2008 M3 with CCC and upgraded to CIC iDrive knob before.
It was plug and play and worked flawlessly right away... You may wanna go check out (and ask) on E90Post side since they've done a lot more of this type of mod than X-side. Good luck.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
06-29-2013, 09:14 AM | #3 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
It is not plug and play, you need to change a line in the cappl module so the car knows it has a new controller.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
06-29-2013, 10:50 AM | #4 |
Rep 6,125
Mine was really plug and play. I bought the trim and knob. That's all I replaced.
06-29-2013, 09:56 PM | #5 |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
On certain month M3s it was a plug and play. Some were not. This was for 2008.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
07-01-2013, 06:05 AM | #6 |
Rep 8
Hi Blue dragon,
I was hoping you may be able to assist as you seem to be one of the guru's on here. Do you know exactly what in the Cappl module I need to re-code? I read somewhere about change the date of the Idrive and also about changing a line entry somewhere I have just bought my K+DCAN lead which arrived friday and am about to build a x86 laptop or a VM so I can use it (providing the . I am fairly IT savvy, so I am hoping I can work it out. I have been reading through the forums but haven't been able to find anything specific to the E70. The part number I have is 9240956 if that helps. Any assistance would be gratefully received Fingers crossed |
07-13-2013, 05:31 PM | #7 |
Rep 1,547
PM me when you have your BMW standard tools installed and working (NCS Expert specifically)
07-23-2013, 10:57 AM | #8 |
Corporate Thug
Rep 76
QQ: I have a 09 & interested in performing the same upgrade, but I read on another forum that once the upgrade to the CiC idrive knob is made that you will lose the rear camera function. Is there any truth to that?
Thanks in advance. |
09-27-2013, 04:10 PM | #11 |
DHS
229
Rep 4,043
In reality its all about having the most updated coding on your vehicle for the E9X M3 platform.
2007-2008 E9X M3s CCC can be swapped out for a direct plug and play with the CIC setup WITH up to date coding and its pretty cheap. I was against it for the past 12 months but then when I found out it costs as much as 8 of my HK AR15 magazines I bought one. LOL
2023 BMW M4 2016 X3 Last edited by Endless619; 09-27-2013 at 04:17 PM.. |
10-01-2013, 08:40 PM | #12 |
Rep 1,547
So he flashed his CAPPL module with 3 series software How about just updating to a later daten version that actually had support for the new controller and just changing the line in the CAPPL.
If your daten version in your CAPPL is too old, obviously its not going to work.
10-02-2013, 10:44 AM | #13 |
Corporate Thug
Rep 76
I thought it was a bit "off" myself. That's why I asked here after reading that awhile back. I thought I'd just install the new iDrive code it to my CCC until I completely gathered all the components for my CIC Retrofit. Which I'm ready to do now
10-25-2017, 11:12 AM | #16 |
Rep 314
Drives: 2006 325xi
Tags |
ccc, cic, idrive controller |
